Author Topic: Sloppy knuckles  (Read 3214 times)
rmoore
  • Turtle Points: -5
  • Male Posts: 44
  • Member since Jan '07
Sloppy knuckles
« on: Feb 16, 2007, 02:48:10 PM »
   I have an 85 straight axle.  It has slop in the drivers side knuckle and I know that it has something to do with the trundle bearings { I think}.  Can any body give me an idea on how to fix this or service the bearings.
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
Re: Sloppy knuckles
« Reply #1 on: Feb 16, 2007, 02:58:12 PM »
what is the preload set on your trunions bearings? have you ever replaced the bearings? if not, they are probably worn out. Jack it up and wiggle the knuckle around see how much play is in it
Quote
rmoore [OP]
  • Turtle Points: -5
  • Male Posts: 44
Re: Sloppy knuckles
« Reply #2 on: Feb 16, 2007, 03:15:19 PM »
There is slop only in the drivers side. I have no idea on how to set the preload.  Is this basically like wheel bearings?  Can I just pull the steering arm off and chek them or do I have to pull the axle and and go thru a bunch of bs?
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Sloppy knuckles
« Reply #3 on: Feb 16, 2007, 05:15:52 PM »
actually  they are  alot like wheel bearings,  the inside rides  on the steering arm  and the outside  , the taper, rides  on the axle ball
if its really sloppy  im sure  when you take it  out  the bearing will fall to peices
but its GOT  to come out.
Marlins  knuckle rebuild kit is like $75  and  has  all the gaskets  and felts/wipers  and the trunion bearings  for both sides  of your truck,
you'll need  some snap ring pliers  and basic METRIC hand tools,
a 10mm,12mm,14mm,17mm
lots  and LOTS  of towels,  a couple of  cans of bearing grease  and  some more towels
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
Re: Sloppy knuckles
« Reply #4 on: Feb 16, 2007, 05:20:42 PM »
I would have to add make sure you are getting STOCK toyota bearings (which are NGK and Koyo) I believe the trunion bearings are NGKs. Dont try to save a buck by getting cheaper kits which do NOT include these... (like the ones trailgear sells, chinese bearings) just my two cents
Quote
Re: Sloppy knuckles
« Reply #5 on: Feb 16, 2007, 05:35:11 PM »
Amen brotha
tufsurf
  • Male Posts: 68
  • Member since Dec '06
Re: Sloppy knuckles
« Reply #6 on: Feb 26, 2007, 07:11:44 PM »
Just finished my "Sloppy Knuckles"   :rofl2: rebuild, used Marlins kit it worked perfect. also used every rag I had in my garage, all my old t-shirts,bed sheets, curtains and any other fabric I could find. get a bucket of grease too. maybe a 56mm socket. research some threads on the subject before you go through all this...as you put it, "bs". you dont want to do this more than once per side.
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
Re: Sloppy knuckles
« Reply #7 on: Feb 26, 2007, 07:43:11 PM »
u mean a 54 mm socket?
Quote
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
Re: Sloppy knuckles
« Reply #8 on: Feb 26, 2007, 07:44:38 PM »
Quote
tufsurf
  • Male Posts: 68
Re: Sloppy knuckles
« Reply #9 on: Mar 02, 2007, 05:37:54 PM »
 :smack: i stand corrected :hammerhead:
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
Re: Sloppy knuckles
« Reply #10 on: Mar 02, 2007, 05:54:05 PM »
thats what i'm here for :yesnod:
haha just kidding cheers :beerchug:
Quote
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
Re: Sloppy knuckles
« Reply #11 on: Mar 02, 2007, 06:10:42 PM »
if your going to do one side, why not think about doing both.  esp if you don't know when the last time the axle was rebuilt.  x2 on the toyota bearings.   And yes repacking the birfs is a greasy messy job, but fun..   :yesnod:
I like to Drive!
tufsurf
  • Male Posts: 68
Re: Sloppy knuckles
« Reply #12 on: Mar 09, 2007, 01:26:35 PM »
gotta admit it all that mess and work was well worth the reward when you drive away and every thing works  :thumbs:
Fearofrunner
  • Male Posts: 620
  • HOW AN 84 SHOULD LOOK
Re: Sloppy knuckles
« Reply #13 on: Mar 09, 2007, 01:50:25 PM »
Come on guy's all this great info and no link for the guy
http://www.birfield.com/~morgan/tech/axle/
thank pirate's FAQ thread, i have used it many time's and has some of the absolute best info! Next to marlin that is  :cool:
http://www.pirate4x4.com/forum/showthread.php?t=459180
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
Re: Sloppy knuckles
« Reply #14 on: Mar 10, 2007, 10:35:58 PM »
  Good Job!  :thumbs:
I like to Drive!
hollywood_toy90
  • Male Posts: 79
  • Member since Oct '06
Re: Sloppy knuckles
« Reply #15 on: Mar 12, 2007, 09:37:05 AM »
this isnt that bad of a job really, if your good it might take you like 30-40 min a side and like i said earlier it really isnt that bad. if you take your time you wont even get that messy, wear rubber gloves when packing the birfs and your hands will stay pretty clean.  i did it this weekend when i re-geared and it didnt take long at all.  make sure when you put the steering arms back on you torque them back to the 100 ft-lbs!!!!! that is very important!  good luck man!!!
P.S. think of the "bs" more as practice for when you are on the trail, the more you have done it the better you will be and faster, which in turns means you are back wheelin faster, and i know we all want that!
Last post Nov 11, 2004, 08:29:35 AM
by 79coyotefrg
Last post Dec 16, 2004, 11:38:55 PM
by kneedownnate
Last post Jan 30, 2005, 03:39:00 PM
by 79coyotefrg
Last post Nov 14, 2005, 07:46:56 AM
by 79coyotefrg
Last post Feb 02, 2008, 06:44:26 PM
by 79coyotefrg
