Author Topic: Test a short block?  (Read 1836 times)
littlejohn
  • Member since Mar '07
Test a short block?
« on: Mar 08, 2007, 06:56:36 PM »
I just purchased a basket case 1985 4Runner.  The engine had a cracked head, and the owner took it apart 2years ago.  Along with the vehicle I got another short block (supposedly good) and a rebuilt head (still in plastic).  Is there anyway to 'test' the spare short block to see if it can be used?  I don't want to put this puppy together, only to find there's no compression.
Thanks
John
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Test a short block?
« Reply #1 on: Mar 08, 2007, 06:58:55 PM »
:welcome:  to marlin John,  well  hows  the  walls  of the cylinders  look??  does the piston  move around in the cylinder  or  do they seem to fit snug??
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
  • Member since Sep '06
  • out from under my rock, and ready to roll
« Reply #2 on: Mar 08, 2007, 07:59:21 PM »
I woul remove the bearing caps and inspect the bearings for whear. This would also be a good time to give every thing a good cleaning and lube the moving parts before reassembly.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
  • Member since Dec '06
« Reply #3 on: Mar 08, 2007, 08:15:10 PM »
Take it to a machine shop & have them check the cylinder bores. They will use a dial bore gauge to check this. Have them inspect everything while it's there. It's worth the money. I rebuilt the in engine in my 83 & didn't check this. The block was no good. Had another block & had it checked. Learning from the school of hard knocks sucks  :smack:
87 4Runner redo
littlejohn [OP]
« Reply #4 on: Mar 09, 2007, 04:12:46 AM »
Thanks for the input-
The cylinder walls look ok, no visiable wear, but I'm gonna have it checked out just to be sure.
John
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
  • Member since Jul '05
« Reply #5 on: Mar 09, 2007, 07:52:10 AM »
Take your fingernail and scrape it around slowly on the cylinder walls.  If anything is bad enough to cause a problem, your fingernail will catch.  This is an "Old School" method, but it works really good if you have the feel for it.
Yota85
  • Male Posts: 63
  • Member since Dec '04
  • Deep Sea Diving
« Reply #6 on: Mar 11, 2007, 10:15:52 PM »
defenatly get some plastigage and check all the mains and rods makes life much easer than trying to change them from the bottom after the motor is in.
83 SR5 short box  5.29 detroit rear aussie front 3inch 33bfg mt's
Last post Jun 06, 2006, 04:26:10 AM
by Sundowner
Last post Nov 08, 2009, 04:44:27 PM
by Confederate13
Last post Apr 30, 2011, 03:32:02 PM
by Broke Okie Rob
Last post Nov 25, 2010, 08:26:30 PM
by wakkjobb
Last post Nov 30, 2010, 10:01:48 PM
by yotatough
