Yeah... thats to be expected from the British... they drink their beer warm!No need for a paper gasket, but you can use one if you wish with a thin layer of the Orange FIPG on each side. I usually remove all the studs from the housing and use a scotchbrite pad on my die grinder to clean the surface. Same on the sealing surface of the 3rd member housing. Then reinstall the studs with a little thread sealing locktite, and run a bead of FIPG on the axle housing, centered on the sealing surface and run to the inside near the studs. Stab the third member in, and torque it down. I usually try to let things sit for around an hour before refilling with gear oil if possible, but it'll work immediately if you need it to.Ryan
Although I am not proud to have broken so many 3rds, I have had unsurpassed success with the Right Stuff. I have learned that a small amount is best, using a finger to evenly spread the stuff around the 3rd.
bump, i need this info now, im on my way to the store before they close
I have seen many diffs leak when the gasket is coated with silicon and then installed. The silicon will help split the gasket and it will leak in time.I used to only use Toyota FIPG but quit due to the high cost involved. At $12.00 per tube it added up quick.We only use permatex ultra grey and have had excellent success. It meets or exceeds the factory specs and comes apart much easier.If the job calls for a paper gasket, i use permatex hightack. Never use silicon on a paper gasket, only gasket cement.We do not use a paper gasket on the rear diff. We only use ultra grey silicon.After the diff is removed, tilt it forward so the gear oil drains out from the pinion recess.Next, we spray the gasket faces with nonclorinated brake clean to remove all oil residue and after a thin coat of ultra grey, button it up.
Started by Brandon General 4WD Discussion
Started by waskillywabbit General 4WD Discussion
Started by Makohon General 4WD Discussion
Started by jimbo74 Chit Chat Camp
Started by lax815 Toyota Pickup/4Runner Tech 1979-95
