Author Topic: 2L Diesel Swap  (Read 4894 times)
TigerToy
  • Turtle Points: 77
  • Member since Apr '04
2L Diesel Swap
« on: Oct 23, 2005, 04:28:38 AM »
Has anyone ever done one of these swaps.  I have an 82 with an L52HD.  The starter is on the opposite side on the Diesels.  Is there a clearance issue?  If so, can I build an exhaust pipe that wraps around it?  Also, does anyone make a high torque starter?  I don't think the stock starter will turn it over, and, as previously stated, the diesel starter is on the left.  Thanks in advance
Willy Mammoth
  • Male Posts: 4,252
  • Member since Nov '04
Re: 2L Diesel Swap
« Reply #1 on: Oct 23, 2005, 06:41:26 AM »
There are others here that can answer with more detail, but I will tell you what I know. You will need the trans that goes with the engine along with the diesel starter.
You can search here for the needed parts. http://car-part.com/index.htm
If you don't already have the 2L I would suggest looking for a 3L because of the lack of power the diesel engines have.
I put a Nissan diesel in my project with a Toyota trans, but this didn't come without lost of custom reworking of the bellhousing.
You to see what I had to go through to get it to work for me here.
http://board.marlincrawler.com/index.php?topic=6472.0
Good luck,
Mark
jr9162
  • Turtle Points: 36
  • Male Posts: 512
  • Member since Sep '04
  • No nookie like Chinookie no butts like Halibuts
Re: 2L Diesel Swap
« Reply #2 on: Oct 23, 2005, 08:10:14 AM »
I'm a member of P.E.T.A.
People Eating Tasty Animals
There's no nookie like chinookie
No butts like halibuts
Fish are not our friends, they're food.
Eat more moose - 10,000 wolves can't be wrong
Calling an illegal alien an "undocumented immigrant" is like calling a drug dealer an "unlicensed Pharmacist".
TigerToy [OP]
  • Turtle Points: 77
Re: 2L Diesel Swap
« Reply #3 on: Oct 25, 2005, 04:04:17 AM »
Ok, I think that I am going to have to do the same thing - cut the bell housing and reweld it, as toyota diesels need to have a left side starter.  Any advice for my welder?  The problem is finding a diesel bell housing.  They made one for the W56 but it is really difficult to find.  I actually think that it will be easier just to go ahead and modify my L52HD
« Last Edit: Oct 25, 2005, 04:08:29 AM by TigerToy »
Willy Mammoth
  • Male Posts: 4,252
Re: 2L Diesel Swap
« Reply #4 on: Oct 25, 2005, 04:19:40 AM »
Don't weld the bellhousing if it is cast iron. It will not hold up. If it is aluminun it can be done, but will need to be 100% without any air pockets and don't grind any welds that don't need it.
If you have a 1 piece block plate for the 2L use it to lign up the starter cone before welding and get it decked before bolting it up the first time.
fritz
  • Turtle Points: 369
  • snow Crawlin'
Re: 2L Diesel Swap
« Reply #5 on: Oct 25, 2005, 05:22:18 PM »
you can easily get bell housings from australia, and you would be suprised how many old toy diesels are in the u.s. a 2l will leave you wanting more power if you like to step on it or drive at high altitudes. it's worth the money for a 2l-t .
fritz
  • snow Crawlin'
Re: 2L Diesel Swap
« Reply #6 on: Oct 25, 2005, 05:26:33 PM »
also, radiator is reversed, and you will need to wire up your own glow plug switch with a hold down style switch, or remake a stock one with toyota or ford relays. you can cut all the other wires out though   :)   and then drive under water    :eyebrow:
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
Re: 2L Diesel Swap
« Reply #7 on: Oct 25, 2005, 07:30:30 PM »
Hey fritz, did they have diesel 4wd trucks over there in the 79-83 body style, or did it only start with the 84s?
TigerToy [OP]
  • Turtle Points: 77
Re: 2L Diesel Swap
« Reply #8 on: Oct 26, 2005, 01:13:34 AM »
I have no worries about it being underpowered because of how underpriced it is, and I don't live in high altitudes.  2LTs are notorious for blowing head gaskets - the guy that has the motor has four sitting in his garage with blown ones.  I can get a brand new bellhousing from Toyota but it is like 350 dollars.  If you have a phone number or link to an Australian yard that might be of help it would be greatly appreciated.  Basically, i want to convert to diesel and then buy a greasel kit to tool around town in.  10c per gallon is my idea of cheap gas.  I will slow my way all the way to the bank.
red
  • Turtle Points: 199
  • Male Posts: 1,616
  • Member since Jan '05
  • irish redhead texan, interesting combo
Re: 2L Diesel Swap
« Reply #9 on: Oct 28, 2005, 11:26:06 AM »
i'm makin biodiesel for my f250, really simple to do and like you said, dirt cheap. if you would eventually like more power there's not much you can do to a mechanical injection, but you could regear your axles.
read and comment :whip:
USAF EOD tech
TigerToy [OP]
  • Turtle Points: 77
Re: 2L Diesel Swap
« Reply #10 on: Oct 28, 2005, 10:47:24 PM »
You got a link to a place that tell you how to make biodiesel?
  • Male Posts: 9,757
Re: 2L Diesel Swap
« Reply #11 on: Oct 29, 2005, 10:05:50 PM »
Yknow, I started thinking, if you're starting with a complete 2L truck I think they came with a W50 tranny, and I'd assume the bellhousing would bolt up to any w series tranny.  I talked to Marlin about this stuff a little some time ago, you might pm him and pick his brain a little.
kyle_22r
  • Turtle Points: 530
  • Male Posts: 1,233
  • Member since Dec '03
  • yellow beast
Re: 2L Diesel Swap
« Reply #12 on: Oct 31, 2005, 10:15:41 PM »
i have heard that earlier trucks('79-83, whenever they started using the diesel in those years) had an adapter ring to fit the L series tranny up to the diesel...
Last post Mar 27, 2013, 01:07:45 PM
by TimberlineBryce
Last post May 28, 2015, 09:49:02 AM
by LittleSteve
Last post Nov 29, 2006, 10:27:48 PM
by kneedownnate
Last post Mar 16, 2010, 12:07:04 PM
by ventureforth
Last post Jul 25, 2010, 10:20:55 PM
by 79toy20r
