Reply #2 on: Jul 02, 2005, 09:40:29 PM »
Begin by checking the vacume diapharm on the front axle, left hand side.
With the engine running, are you getting vacume to both lines when you shift in and out of 4wd?
The 4wd light will only light when the diapharm moves the shift collar to enguague into 4wd.
There is a vacume resivoir behind the front right inner fender liner.
I have had to replace the two vacume switch valves on the right fender skirt in the past.
![](https://board.marlincrawler.com/Themes/MCI_V3C/images/ip.gif)
Logged
