Author Topic: Tacoma Rear Axle Options???  (Read 4870 times)
TrailsLessTraveled
  • Member since Aug '02
  • I love Marlin Crawler!
« on: Dec 07, 2002, 08:07:30 AM »
I just bought a 96 4cyl/5spd Tacoma and the axle code says that it has 3.58's!!!, and a 7.5" ring gear.
I de-coded two friends TRD V6/5spd Taco's and they both have 4.10's but also only have the 7.5" ring gear diameter. What gives? I thought all the 4wd trucks used at least 8" rears. Some charts say there is an 8" version, others say only an 8.4" (Tundras, LC's?).
I need to re-gear to turn 33's and I'm thinking about using 4.56's or 4.88's. I already have a 4 pinion 8" third member with 4.56 gears in it from a 89 Toyota. Is this easily adapted? Axle spline count, bolt pattern, etc. I've heard that the factory lockers can be used in older housing without any problems, so can I assume the same in reverse?
Or should I buy a 7.5" factory locking third member with the right gears? I'm just wondering why the apparent set backwards in size and strength, or if there is some improvement made to the newer 7.5"s.
« Last Edit: Dec 31, 1969, 04:00:00 PM by 1056988800 »
krawlr
  • Member since Oct '02
  • ManBearPig Rowrrr!
    • Krawlr website
Re: Tacoma Rear Axle Options???
« Reply #1 on: Dec 08, 2002, 05:38:39 AM »
Tacoma is 7.5" in front and 8.4" in the rear 8" if it has the TRD electric locker.
I'm running 5:29's with an auto but you may want to step down to 4:88 if you have a 5spd.
Don't know if the older third will fit or not. I know the TRD locked third has a funky bolt pattern but can be adapted to the non TRD housing with fab work.
27-AT, some other adapter, flipped D300, twin sticks on cables.
[shamelessplug] www.krawlr.com [/shamelessplug]
Don
TrailsLessTraveled [OP]
« Reply #2 on: Dec 08, 2002, 05:15:06 PM »
So does the non-TRD Tacoma housing use the same third member bolt pattern as the older Toyotas? Does that mean that my 8" V6 third member will bolt right in?
What about the front third member; is the 7.5" the same as in the older trucks? I'm looking for donor 4.56's.
krawlr
    • Krawlr website
« Reply #3 on: Dec 09, 2002, 02:40:44 AM »
Now that I think about it, I can't remember if it was an older style housing or a Taco housing where I saw that done. Think I saw it on POR, let me dig around.
The Taco front is an oddball, will not take gears from earlier models. It will take a Lock-Rite from an earlier IFS and ARB now has a locker for it.
Don
krawlr
    • Krawlr website
« Reply #4 on: Dec 09, 2002, 11:41:29 AM »
Here's the article, doesn't answer your question though.
http://www.4x4wire.com/toyota/tech/electric_locker/
With a tube of sealer and a few qts of gearlube you could find out for sure. :greengrin:
Don
« Reply #5 on: Dec 09, 2002, 12:30:13 PM »
The articles I have seen about the TRD locker swap were into older Toy axles. So, I'm wondering if the housing shares a pattern with the older, non-locker axles, or has the same pattern as the locking diff models. Thanks for the help and suggestions so far Krawlr.
Can ANYBODY resolve the mystery as to why 4wd trucks, especially V6, TRD models would come with the 7.5" diff?
krawlr
    • Krawlr website
« Reply #6 on: Dec 11, 2002, 02:56:07 AM »
Ok, just found out the 8" thirds will not fit the newer 8.4" housings. You'll need the housing that goes with that '89 third to use it.
Don
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #7 on: Mar 19, 2003, 10:58:03 AM »
Quote
:oops:basically  its so you CAN'T do what you are wanting to do :psss:but what they dont realize :screwy:is we dont stop modifying our trucks because they make it harder to do it
Last post Jan 08, 2003, 10:46:06 AM
by TrailsLessTraveled
Last post Mar 03, 2004, 03:04:59 PM
by conflict
Last post Jun 29, 2005, 08:33:46 PM
by coconut
Last post Jun 06, 2005, 11:57:48 PM
by tdawg
Last post Nov 02, 2006, 06:44:05 PM
by fabtoys
