Author Topic: Single low gear case or dual case for '91 V6 Extra Cab???  (Read 1655 times)
beefyjw
  • Member since Aug '13
« on: Aug 16, 2013, 01:09:06 PM »
I need lower transfer case gearing, but i don't necessarily need "dual case low". I assumed single case 4.7 gears would be cheaper than a dual case setup, but then i read that the V6 toys require an adapter and driveshaft revisions even for the 4.7 gears. My question is simple...
What would be the approximate cost difference between a single case low gear and a dual case setup for my truck? Is a 4.7 swap out really not possible for my truck without driveshaft changes?
I have a 1991 V6 Toyota Pickup Extra Cab on 33" tires with a 3" suspension lift.
« Last Edit: Aug 16, 2013, 01:20:21 PM by beefyjw »
1990 Pickup XCab V6 3.0 SAS (in progress)
'83 8" trussed front axle rebuilt w/ marlin stuff
longfields, yukon 4:56, high pinion
4" All Pro Springs
33"x12.5" BFG KM2
Detroit locker in rear
ARB Locker in front
Rancho Shocks Rear/Bilstein Front
Aisin Wheel hubs with 6 ARP studs and 6 pins each
Strong Idler Arm with brass bushings
Custom runner bars/custom roll cage/custom tire carrier
Rockcrawlintoy
  • 4 doors for more whores
  • Turtle Points: 2147
  • Male Posts: 2,339
  • Member since Dec '03
  • RIP Kyle
    • Buy me a soda
I always say do dual cases. The main reason is that you can still keep stock 4 low.
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Adapter--Yes
D-shaft work--No
beefyjw [OP]
Thanks... so DCase conversion $1600 or so.....4.7 gears/adapter/DShaft $1000?
4" All Pro Springs
33"x12.5" BFG KM2
ARB Locker in front
Last post Oct 12, 2005, 03:46:55 PM
by MiniSimp
Last post Jun 29, 2006, 08:23:10 PM
by Weldo
Last post Aug 12, 2017, 08:51:37 PM
by TURBO
Last post Jun 21, 2008, 03:54:25 PM
by Slolyfe
Last post Aug 13, 2008, 08:55:24 PM
by focushere
