Are you pumping the gas pedal once or twice before you go to start it? I know in my 82 if I didn't pump it a few times to squirt some fuel into the venturies it would fire up right away.The mechanical fuel pumps take a little while to draw fuel up to the carb if they have been sitting too something to think about.
just started haveing this same issue but with a efi any ideas?
my 84 (carbed) dd is having issues starting. i think its fuel related. it starts fine most of the time but like twice a day it will not start. ill crank it on an off for 3-5 min and eventually it decides to start.the choke works, its getting spark and if i give it a shot of starter fluid it starts. i admit do to lack of time i havnt tried to hard to figure it out. i was hoping to get some ideas before i go after it.
Curious, how does it run after it starts? fine or crappy?
Started by Truggy Engine
Started by BLACKDOG General 4WD Discussion
Started by 4x4Haze Toyota Pickup/4Runner Tech 1979-95
Started by stinger Engine
Started by 83yota5960 Engine
