Author Topic: is there a complete kit for rear chevy springs somewhere out there?  (Read 2612 times)
907yota
  • Turtle Points: 8
  • Male Posts: 153
  • Member since Jul '07
Hey all,
I just scored some rear 63" chevy springs... is there a complete kit that i can order for this swap? i saw a couple companies out there but none of them seem complete w/ everything you might need...which brings me to my next ?... can anyone put a list together with everything i need for the swap.... please and thankyou
P/s
ive never done this before just helped a buddy install marlins rear kit w 4" springs
907yota
86 reg cab turbo,99runner,95pickup all 4x4
09 honda rincon 680cc 4x4
2000 yamaha badger 80cc (for the kids)
Chicken nutt bread!!!
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
  • Member since Sep '09
    • Poly Goats
OldGold3VZE
  • Turtle Points: 4
  • Male Posts: 417
  • Member since Feb '08
  • Run whatcha brung, and have some fun!
    • Light Racing, High Performance Bump Stops
Sky manufacturing makes one, but this "kit" can be made easily at home with a foot of 3.5" x 3.5" .250" wall square tube and an angle grinder and a drill press.  Cut the square diagonally with your angle grinder leaving a 2-3" flat spot on either end, then slice off the bottom, and drill holes.  It's really easy.  If you don't have shackles, just cut up some 3/8" x 2" strip steel and drill holes.  It's an afternoon job if you're motivated.  I think I have some pics in my build thread.
My 1980 Long Bed build thread
http://board.marlincrawler.com/index.php?topic=84562.0
Truggy build thread
http://board.marlincrawler.com/index.php?topic=89844.0
Rastafari Livity!  Ital = Vital!
907yota [OP]
  • Turtle Points: 8
  • Male Posts: 153
thanks guys, i searched but thought maybe somone would know of a specific company that would have a complete kit with everything needed...peterbuilts thanks for the search those never came up when i did it
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
907yota [OP]
  • Turtle Points: 8
  • Male Posts: 153
thanks cheesemaker
I just scored these 63's for 20 bucks there a little rough but not pitted or anything.... the bushings look like their not coming out without a fight, is there an easy/better way to remove these without breaking out a torch?
OldGold3VZE
  • Turtle Points: 4
  • Male Posts: 417
Is there an easy/better way to remove these without breaking out a torch?
Nope
Truggy build thread
fordh8r
  • Turtle Points: 850
  • Male Posts: 2,588
  • Member since Jan '07
  • when my toyota grows up it'll be just like my chevy!
  I use a hole saw just bigger than the inner metal sleeve to cut through the rubber. Then with an air hammer, you can knock out the shell from the spring eye using a chisel bit while running it along the spring eye's groove (where the end of the leaf wraps back around and contacts the spring again).
 When you go to install it, I use a long piece of all thread (preferrably as big as will fit through the new bushing) with some large washers (or a metal plate that spans the spring eye opening) against the spring eye opening and a socket that fits over the edge of the rubber of the new bushing and contacting the metal shell of the bushing with nuts at both ends of the  all thread and just run it down. The new buishing will slide right in and it"s self aligning as you go. Use a little anti-seize on the shell of the new bushing too. Hope that helps.  :beerchug:
907yota [OP]
  • Turtle Points: 8
  • Male Posts: 153
thanks fordh8r,
i was told to just use a torch and burn um out, but your way sound easier on the springs...ive been collecting these parts for some time now but still have a ways to go...cant find anything in my little town, craigslist has been my freind..should i rebuild these with new slipper sleeves or just leave the stock ones in there after i paint them
fordh8r
  • Male Posts: 2,588
thanks fordh8r,
  Right, I've never been a fan of putting flames to springs myself.  :nope:  Even if the flame is concetrated on just the bushing. Plus, that :pokinit: STINKS forever!  :ack:  I discovered this method when I was a broke  :moon: , I never had a torch available to me, so I used what I had and it seemed to work nicely. Sometimes you have to come from both sides with the hole saw to get it out completely but it will come out.  It's still a little stinky but not nearly as much.  :gap:
  I had a buddy whose poorly routed exhaust had burned his bushing away and we were able to change his out while on the truck in about 15 minutes. But not before he had his exhaust rerouted as to the cause for changing the bushing in the first place. Granted, the rubber was already gone at that point, but that just saved us one step.  :thumbs:
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
    • Poly Goats
Not sure if you have access to a press, but that would probably work pretty good.
85runner_
  • Turtle Points: 2
  • Male Posts: 204
  • Member since Dec '07
I just left the bushings in. Mine weren't that bad. The hole saw idea seams legit
Last post Jun 23, 2004, 02:38:41 PM
by TigerToy
Last post Jan 04, 2005, 11:46:54 AM
by BUILTTOY
Last post Feb 15, 2005, 02:42:58 PM
by UNBREAKABLE
Last post Apr 13, 2005, 07:37:39 AM
by TRDISMO
Last post Apr 12, 2006, 09:31:48 AM
by trax28to
