Author Topic: 86 motor to a 81 chassis  (Read 2666 times)
rgacord
  • Male Posts: 88
  • Member since Mar '10
  • life is good today
« on: Mar 08, 2010, 09:22:15 AM »
i have a 86 pickup with a good motor, trans., transfer., and rear axle, the body is junk. i picked up a nice 81 pickup with a blown motor. problem is, some one had just cut the wires to the motor off at the right fender of the 81. i believe there are 6 or 7 wires, color coded, but the don't all match the colors of the 86 motor. i do have the intake for the 81 if i need to swap it. ant help would be greatly appreciated.  :hammerhead:
I don't care that "it's a jeep thing" as long as my mail gets here on time
CrazyYota
  • Turtle Points: 92
  • Male Posts: 1,072
  • Member since Oct '05
Re: 86 motor to a 81 chassis
« Reply #1 on: Mar 08, 2010, 10:28:42 AM »
if your going to keep the carb the 81 intake will bolt up to the 86 engine. I have a 85 celica engine in my 83.
rgacord [OP]
  • Male Posts: 88
« Reply #2 on: Mar 09, 2010, 04:09:28 PM »
thanks for that, but what about the wiring issue
ROCKO
  • Turtle Points: -49
  • Male Posts: 743
  • Member since Sep '07
  • NOR-CAL WHEELIN
« Reply #3 on: Mar 09, 2010, 04:12:22 PM »
use the wiring harness, steering wheel and cluster out of the 86 and it should be plug and play..
i'm in the process of doing that right now but its a 88 22re into a 85 truck
JUST ANOTHER ROCK CRAWLER....
with a lot of good stuff
F@$K CANCER
rgacord [OP]
  • Male Posts: 88
« Reply #4 on: Mar 11, 2010, 09:18:37 AM »
thanks,,,,i'll check it out :thumbs:
THE ROCK
  • Male Posts: 219
  • Member since Apr '07
« Reply #5 on: May 10, 2010, 11:53:42 AM »
 :usa:Just completed one in a friends truck..88 efi in an 85 carbed truck...used the 88 cluster and the entire 88 dash/ engine harness, swapped tanks(fuel pump)... The ca. smog rep stated that it was a perfect swap/ passed the visual and ca smog w/ flying colors! dont short cut by chompin up the harness to save time and be sure that the o2 sensors are all in the "original" 88, in our case,location..the referee stated that this is where a lot of ( otherwise good swaps go bad) :clap:..take your time, do it right, do it once...the swap was easy, the wiring can be a bleep..Have a FSM handy, haynes and Chlymer, and Chilton manuals are somewhat vague in this area :twocents: :crossed: Good luck! :beerchug:
SAUBEL
  • Member since Oct '10
« Reply #6 on: Oct 12, 2010, 09:52:58 PM »
i have a 83 and im putting a 22re in it so what your saying is use a complete engine and under dash harness for the 22re
Last post Nov 06, 2007, 06:06:33 PM
by KDXSR5
Last post Jan 27, 2009, 09:49:53 PM
by DTB
Last post Apr 25, 2010, 12:47:04 AM
by havik
Last post Nov 06, 2009, 10:42:06 AM
by Loosekannon
Last post Oct 25, 2011, 09:42:42 AM
by Lizard_lips
