the problem is i can't move the shackel hanger back because the frame has been choped be hind the shackel mount.
i was thinking of just moving the front mounts a little more forward to compinsate. n i was noticing that i cant go to far forward or the axle would hit the gas tank when it flexes. i have about 5-6 inches between the axle and the tank as it stands now.
also what is a good shackle angle to work with. i have herd that when the truck is in the air,the shackles should be near vertical.
I have a 79 toyota pick up long bed. im going to be installing traillgears 5" lift kit. i know i have to move the spring mounts forward. the problem is i can't move the shackel hanger back because the frame has been choped be hind the shackel mount. i was thinking of just moving the front mounts a little more forward to compinsate. Has any one done somthing simmiler? than i was noticing that i cant go to far forward or the axle would hit the gas tank when it flexes. i have about 5-6 inches between the axle and the tank as it stands now.would the axle go that far forward? also what is a good shackle angle to work with. i have herd that when the truck is in the air,the shackles should be near vertical. does that seem right? i know it sounds confusing, and why dont i just go try it and see what happens. was just wondering if im the only persone that has come across this problem, and i would like to try to eliminate any problems before i tear into somthing this deep. any info, advice or constructive critisim would be apreciated.
I'm sure there are people here that have put tg springs on their vehicle that could help you answer this question. Now the question I'd have is since tg has their own bb why not ask there instead of a competetor of tg. For me this doesn't make sense. Actually it does but I won't go into that and open another can of worms. So does anyone have an answer to this question rather than just turning this into another bash tg thread?
but BUT
Started by mudn4rnr New Announcements and Info
Started by Alpendubber Toyota Pickup/4Runner Tech 1979-95
Started by TopStreet Parts For Sale
Started by charlieknuckles Rigs For Sale
Started by Mr_Cheese Parts Wanted
