arent the galleys the canal shaped metal rod/pin things that go from the front to back of the case, because I thought they just helped in the assembly of the case.Mine were being difficult, so I just left them out. over 1000 miles since then and this case hasnt blown up yet.
yes, you need those, the send oil to the rear bearing on the output shaft.
in the full tcase
I'm good then I was referring to the crawl box. also does anyone know where I can get a top shift case from I have two side shift cases and I know now I can use the side shift case for my crawl box but I need the top shift for the rear case. "I think"
Started by Thomas P Parts Wanted
Started by NATO4X4 Toyota Pickup/4Runner Tech 1979-95
Started by Boheefus Toyota Pickup/4Runner Tech 1979-95
Started by BigMike « 1 2 » Engine
Started by Wainiha Transmission/Clutch
