W59 Reassembly question
Started by Wainiha, May 29, 2014, 05:35:22 PM
Wainiha
I have a W59 I took apart.  It was my first oppurtunity to look inside of a transmission and learn.
I'm ready to put back the two case halves togethor -  RTV right?
It never had a shifter and I used a metal punch to shift it between gears to check the shift fork movement.
Does it need to be in a certain gear when I close it up?  Any issues with installing a shifter afterwards?
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
King resi C/O
and Total Chaos UCAs
emsvitil
If you're using the paper gaskets, I prefer smearing Hylomar on both sides of the gasket.
With no gaskets,   I'd use Hylomar or ultra grey or ultra black
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Wainiha
No papaer gaskets.  So staight RTV.
Does it matter what position the shift rails are in when I close it.  I want the next person to be able to install a shifter w/o splitting the case open.
Icon C/Os
FLOODED...GONE
FLOODED...GONE
King resi C/O
Wainiha
Put it in neutral so the shifter can be installed?  Does it matter?
Icon C/Os
FLOODED...GONE
FLOODED...GONE
King resi C/O
emsvitil
I was probably in neutral when I put my W56B back together.....
:dunno:
Don't think it matters.
Just make sure you can get all the gears before the RTV dries.
I didn't put the shifter back on until it was installed
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Wainiha
Icon C/Os
FLOODED...GONE
FLOODED...GONE
King resi C/O
