The isolator only lets one charge at a time
Why not just run an Optima or something similar?
That's how we run em, but that would entail taking the factory harness out of the equation wouldn't it?
I have been running dual orbitals for 3 years with no isolator. never had a problem. just hook them parallel. isolator is to stop the batteries from draining each other. but this is not as much an issue if you get the batteries at the same time (and same numbers) from the store and hook them up. the problem occurs when you use one old battery and one new one. or a pair of old ones.
OK, I just re-read this again. Apparently I have had my head up my ass, you guys are right. The isolator just prevents them from draining each other. The batteries will charge simultaneously.
But then you have no selectability...all the cool guys have switches!
i have mine hooked up in paralel I haven't had any probs yet. Red Top and Water Battery for now till i can afford another blue top.
Can't remember why just now, but it's supposedly a big no no to hook gel and wet together.
Started by Westy Engine
Started by JOE 88 Toyota Pickup/4Runner Tech 1979-95
Started by Hurricaneinmotion Project Research and Build-Ups
Started by accountant_mechanic_ Toyota Pickup/4Runner Tech 1979-95
Started by toyodaaddict Newbie Questions
