Austin, TX area. Will ship for $10.
Hayes brute clutch kit. For 22RE - HAY-90-400 1985-1995
New. Never installed.
I made a mistake, I've got a 22RTE flywheel, which requires a bigger clutch.. My rotating assembly is already balanced and I can't use this.
"Clutch Kit, Organic, 1 1/8 in. Diameter Shaft, 21-Spline, 8.875 in. Diameter Disc, Toyota, 4Runner/Pickup, Kit"
"Hays Super-Brute clutch kits are intended for severe-duty usage, including such tough-on-equipment activities snow plowing and commercial towing. They're designed and manufactured with top-quality parts, featuring diaphragm-type pressure plates and clutch discs that have sprung hubs and organic linings. Kits come complete with pressure plate, clutch disc, throwout bearing, and clutch-alignment tool (most kits). Pilot bushing not included. "
"Engineered and built as a matched assembly, each kit will provide exceptional performance, durability and long term dependability. Each kit comes with; Performance pressure plate, clutch disc, throw-out bearing, clutch pilot alignment tool"
Comes in original box. with everything mentioned above.
![](http://www.jegs.com/images/photos/400/490/490-90-400.jpg)
