Author Topic: 7.5 IFS 4 cyl vs 6 cyl difference  (Read 903 times)
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« on: Sep 13, 2021, 04:16:32 AM »
I was on the store site (dreaming) and noticed that there's a 4 cyl and 6 cyl 7.5 IFS diff rebuilt kit.
What's different between the 4 cyl and 6 cyl IFS 7.5 differential?      Looks like they use the same R&P.......
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
emsvitil [OP]
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
Re: 7.5 IFS 4 cyl vs 6 cyl difference
« Reply #1 on: Sep 29, 2021, 02:29:16 PM »
Here's what I found out:
The housing is the same.
The R&P are the same.
The difference is the carrier and carrier bearings.
The 4cyl is supposedly 45mm and the V6 50mm ID bearings.   Both have 80mm OD.
If you have the ADD (automatic differential disconnect) you have 50mm.     (plus the carrier hub is bored out for a roller bearing)
The ARB RD90 uses 50mm bearings.    (I think there is an older ARB that used 45mm)
There is a 45mm (911A445) and 50mm (911A342) Truetrac carrier.
The thing is, from digging thru the Toyota epc data;    It looks like Toyota made a running change to 50mm bearings and carrier before the V6 arrived.
So you don't know what you have until you take the differential carrier out.............
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
- Sales Employee -
KDNICKELS
  • Hawk
  • Turtle Points: 502
  • Member since Apr '19
  • 1998 Toyota 4Runner
« Reply #2 on: Sep 30, 2021, 02:03:38 PM »
That is correct, they use the same ring/pinion but will use different bearing kits, as they have different size bearings.
Last post Jun 15, 2005, 11:09:46 PM
by guywithuglyyota
Last post Sep 04, 2007, 01:38:47 PM
by skyscraper
Last post Nov 05, 2007, 09:59:43 PM
by kneedownnate
Last post Aug 16, 2012, 10:24:42 PM
by SFD4x4
Last post Jan 03, 2022, 11:28:32 AM
by RUGER
