Author Topic: 22re need help asap!  (Read 3021 times)
mudcrawler87
  • Turtle Points: -14
  • Male Posts: 10
  • Member since Jul '15
« on: Jul 24, 2015, 11:49:04 PM »
ok so im trying to get into crawling and such and my parents gave me my dads old truck, its a 1987 pickup 22re efi. so i rebuilt the whole engine, pistons, honed the cylinders, and some other stuff. i did it all my self except putting the engine back in the truck, i have all the electrical hooked back up and i, still trying to find a vacuum hose diagram to put the hoses in ghe right place, i replaced the distributor with a brand new one and i replaced the relay under the dash the open relay. i have done all this work and when i go to start my truck the fuel injectors arent opening neither is the cold start, i checked all the wiring and none of it seems bad, i dont knwo what else to do i need some major help! if anyone knows what my problem is please let me knpw i have no other ideas this was supposed to be a twe week project its turned into a 4 month project and almost 2 thousand dollars. i really just want to hop behind the wheel and drive her asap so please help me! ive looked allll over the internet and ive replaced all the parts they say to and still no fuel to the cylinders, not a drop.
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
Re: 22re need help asap!
« Reply #1 on: Jul 26, 2015, 07:12:42 AM »
try this.
http://www.4crawler.com/4x4/CheapTricks/index.shtml#FuelPump
Check your relays and fuses to make sure they are working.  A volt/Ohm meter was my best friend and the Factory Service Manual when I swapped out motors.
jssgbsn
  • Turtle Points: 440
  • Member since Sep '13
« Reply #2 on: Jul 26, 2015, 08:03:04 AM »
Was the truck running before the rebuild and extra work?
If I don't ask the stupid question, who will?
85 Runner, 22RE, AEM 'warm intake', TRD Cam, LC Headers, Dual Case, 5.29's, ARB Front Locker, Detroit Rear Locker, 35's, V6 Brakes, ARP Studs, Marlin Arms/Caps/Hy-Steer, Winch, Armor, Can-Back Top....and...
...more Gremlins than Gizmo the Mogwai was responsible for.
jssgbsn
« Reply #3 on: Jul 26, 2015, 08:17:41 AM »
http://mobile.pirate4x4.com/forum/toyota-truck-4runner/579557-22r-22re-22rte-vacuum-diagrams.html
http://s5.photobucket.com/user/OlBlueCJ7/media/Toyota%20Vacuum/1985-87Toyota22RE.gif.html
thus is a quick result i got off google.  i think it only shows vacuum for the emmission stuff.  guessing yiu also have a booster, maybe cruise also?
jssgbsn
« Reply #4 on: Jul 26, 2015, 10:13:05 AM »
Also, bookmark this website http://www.pirate4x4.com/forum/toyota-truck-4runner/775780-toyota-bible-faq-2-0-a.html
And here is a thread with lots of 22RE engine bay pics where you can visualize the the spaghetti nightmare of 22RE vacuum lines...http://www.pirate4x4.com/forum/toyota-truck-4runner/238808-need-help-22re-install-2.html
Good luck with the fuel prob.  I don't have any good advice for that part :(
Slabzilla
  • Turtle Points: 1355
  • Male Posts: 539
  • Member since Dec '13
« Reply #5 on: Jul 26, 2015, 12:10:13 PM »
Just a thought, but did you connect the black with white striped ground wire to the stud on the split in the intake manifold.  This wire sometimes gets overlooked when installing engines or intake manifolds as it just drops down when disconnected upon engine removal.  Injectors/engine won't run without this connected. :smack:
'85 Xtra-cab, 4.5" Downey Off-Road lift, 12-15 KM2's on American Racing Baja's, Marlin's-4.88's & 4.7's, Downey Off-Road CAI, Marlin rear bumper & sliders
mudcrawler87 [OP]
  • Male Posts: 10
« Reply #6 on: Jul 26, 2015, 02:26:50 PM »
yeah i connected it, my trucks vacuum lines are all weird ill try yo post a picture of what its like as of right now so you guys can see, ill also check those websites you posted to see if any of that helps
jssgbsn
« Reply #7 on: Jul 26, 2015, 02:58:34 PM »
I also sent you a PM (private message) if you wanted me to send you a digital copy of a FSM.
mudcrawler87 [OP]
  • Male Posts: 10
« Reply #8 on: Jul 27, 2015, 12:21:28 AM »
didnt get your pm for some reason, but i tried everything on the websites, im thinking about pulling the motor again, my parents said i have until this weekend to get it done or they are going to sell it, and i cant work on it tomorrow because my doctor wants to test me for skin cancer all day. im thinking about just purchasing a new computer and buying some new relays just to try those, im open toanything you guys say i should try im pretty much desperate to get ths going before mt 17th birthday next month, thanks for all the help so far though guys
jssgbsn
« Reply #9 on: Jul 27, 2015, 03:19:02 AM »
Good luck, if you think a FSM would help check the 'MSG' tab for your personal messages.
It goes Home>Store>Arcade>Profile>MSG>Calendar>Members>Logout
At the top of the page just under your profile picture.
Again, good luck.  Hopefully you can figure out why fuel isnt delivering.
Lobo176
  • Male Posts: 34
  • Member since Feb '16
« Reply #10 on: Mar 11, 2016, 05:26:55 PM »
Did you ever get it running, if so what was the problem?
85 SR5 long bed, 22RE, original owner, paint, and interior.
8" lift, 35" All Terrains, 5.29's W/TRD limited slip front, Detroit rear.
Last post Apr 08, 2006, 12:48:20 PM
by 89 toy
Last post Nov 11, 2007, 02:26:49 PM
by unclejpl4x4
Last post Aug 01, 2013, 12:06:23 PM
by Cheesemaker
Last post Jul 25, 2015, 07:27:41 PM
by 1985CRAWLER
Last post Aug 13, 2015, 08:44:34 PM
by Dirt Mover
