Author Topic: 3RZ swap Auto transmission wiring  (Read 5636 times)
zooky
  • Member since Feb '05
Re: 3RZ swap Auto transmission wiring
« on: May 20, 2009, 05:50:16 AM »
If you have deep pockets you could use the 2wd taco tranny with an adapter and a gear driven case.
There is a Volvo transmission that will work in the toyota. There are NO wires to hook up. The toyota 2wd bellhousing will bolt right up to it. I made an adapter to mount a gear driven T-case to the back of it. The transmission I used had a 23 spline output that matched the toyota T-case splines so making a coupler was easy. The transmission cost me $59 and I made the adapter in my driveway for like $100, no special tools. So it can be done cheap.
Here is a pic, that is a Suzuki bellhousing but the toyota bolts on just the same:
Last post Feb 01, 2005, 10:08:58 PM
by scheid6996
Last post May 02, 2005, 04:33:22 PM
by morerunner
Last post Feb 15, 2006, 05:37:53 PM
by 79coyotefrg
Last post May 23, 2010, 07:29:28 AM
by SolidAxle
Last post Dec 08, 2010, 07:25:52 PM
by zippo
