I did the flasher mod to keep the flashers from flashing quick like a bulb is burnt out. It worked for a couple weeks but now nothing. I keep thinking either a short or the turn signal switch. The fact that is does it when the brakes are applied makes me think short where the brake light switch is giving the harness ground. but then why would it do it when the wheel is turned left?? That makes me think turn signal switch because it is the only part that is affected be the wheel turning. I don't know... arghh this is why I hate wiring..
