Exactly what I'm headed towards but usually there's not a common ground for something such as these small circuits it's usually a couple different smaller grounds as I'm asuming it's like almost every other one out there. Is there any specific fuse I need to check such as the fuse for the running lights, I don't remember there being a dash fuse and the dash fuse is tied in with something else but I don't recall what. I know you mentioned a fuse could be back feeding so that's why I'm trying to piece something together so I can get this figured out
I've already tried the multi function switch relay and eliminated that. I'll check my bulbs too, the dash is grounded through the dimmer switch I'd I remember correctly (Which has always been finicky on mine before). I appreciate all the help I was to to point of
this thing until I had to cool down for a couple days. Gotta love yotas wiring setup
, I know it can be my own fault cause I'm overlooking a wiring harness that's probably in reality really simple. Thanks for the feedback
