OK I got it running today. I got 3" from the radiator to the pullys. with the stock 7M radiator I had in there I only had 1/2"
My question is.
I need to make a shroud and use electric puller fans. How much space do I need to have inside the shroud? (between the radiator and the inside of the shroud) Plan to just make a box, and bolt the fan/fans to it where the motor wont get hit by a belt or pully.
Here are some of the latest pics.
Engines
http://home.fuse.net/PaulE/truck/7m013210.jpghttp://home.fuse.net/PaulE/truck/7m013229.jpgNew hole to reroute the wires.
http://home.fuse.net/PaulE/truck/7m013303.jpgNew Engine in the truck.
If you look close you can see the loom from the fuse box to the firewall and across. I am still leaving the bat and headlight wires across the core. Since I will take the bat out is I am tearing the front off. And the headlight is any easy plug to get to. The other wires went in without splicing since I drilled the hole.
http://home.fuse.net/PaulE/truck/7m023116.jpgjunk AC compressor , checking for space.
http://home.fuse.net/PaulE/truck/7m023542.jpg16 days till i leave for Moab. And I still need to replace the front springs, adn figure out how to mount the bumper. I also need to get the AC running, but that won't keep me from going. Just make me more comfortable.
