« on: Jun 12, 2005, 08:32:58 PM »
I have gotten rid of the noise by putting a blow nozzle thur the fork boot and giving it a good blow.
The fine dirt in the bellhousing should help lubricate the squeak.
![](https://board.marlincrawler.com/Themes/MCI_V3C/images/ip.gif)
Logged
