Author Topic: Throttle body injection  (Read 2474 times)
Bluewatervet
  • Turtle Points: -108
  • Male Posts: 63
  • Member since Oct '14
« on: Dec 04, 2014, 11:48:44 AM »
Found this site.. Affordable-fuel-injection.com
They offer a Tbi kit for Toyota 22r and the strait 6 motor. Has anyone here used this setup? It about $1000 minus shipping. I think it would be more cost effective than swapping all the carb stuff for efi.
« Last Edit: Dec 04, 2014, 11:58:13 AM by Bluewatervet »
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
Re: Throttle body injection
« Reply #1 on: Dec 05, 2014, 09:48:00 AM »
I've heard of guys modifying the TBI off a 2.5 GM 4 cyl to work on the 22R's.
After a quick search, if your handy with electrical stuff, find a TBI off a 2.8 v6, swap in the injectors from a 2.5 4cyl, and it should work.  Just need all new sensor ecm and such.  I need to maybe do some research on this.  It has been one of those in the back of my brain things, ever since I read about it years ago.
Bluewatervet [OP]
  • Male Posts: 63
« Reply #2 on: Dec 05, 2014, 03:31:34 PM »
That sounds much cheaper and I'm not too bad with electrical, but don't think that's something I would try. Unless the parts were stupid cheap.
dcg9381
  • Member since May '05
« Reply #3 on: Dec 15, 2014, 12:23:32 PM »
I built a 22R supercharged (Camden/LC Engineering) rig.   The supercharger was draw-through and had an option for a holley carb.
I found an adapter for holley to TBI style and dropped in a TBI from a 4.3L Chevy.
I controlled it with megasquirt.  All of the wiring was simple add in.  No timing control, the 22R timing is mechanical.  All said and done, under $500...
The 4.3L is a lot of carb for 22R, even a supercharged one.   Likely a smaller TBI would be better.
"Fuel only" megasquirt is relatively easy, assuming you've got reasonable computer and wiring skills.
Last post Sep 01, 2004, 10:10:08 PM
by Marlin
Last post Jan 13, 2006, 12:02:16 PM
by olemisstoy88
Last post Oct 10, 2009, 07:33:16 PM
by Tyler82toy
Last post Nov 04, 2010, 07:01:32 PM
by franky112665
Last post Feb 23, 2014, 07:14:46 AM
by sirdeuce
