My question is about the overall lift height and the rear suspension. For the front I would like to use the 3 link setup from 4Wheel Underground. For the rear I think it will have to remain on leafs for budget purposes. If using the 4Wheel Underground setup what height kit would the rear need to be? I want to keep the cg to be as low as possible and am not completely against some fender trimming to keep it low. Thanks in advance for the suggestions.A couple of old photos
Sounds like you've got great plans!! There are a lot of factors that decide your ride height you should contact Brian from 4wheelunderground.com he is an above and beyond great guy and knows his stuff no doubt, he will get your questions answered right away! Brian can answer your questions in a far better explained manner and might even do so right here below this comment. FWIW: I have my rig setup with a 4wu 3 link front, 16" radflos , and the rear is 63" chevy rear springs. I wish for road manners that I had spent the extra money and linked the rear of my rig, my front end is miles better to drive than it would be with springs and with the rear linked also my rig would feel almost like a factory lifted truck essentialy( and im on 39.5" iroks running dana 60's front and rear for axles).
FYI contrary to popular belief, length of coilover will not affect ride ht. But desired up travel will. For reference use 26" at the frame (level frame) on 37" as the standard. This equals 5"s of lift over factory. On 35" tires you'll be at 25". And with 35" tires and 4" of lift you'll be at 24". Plan accordingly and it should be easy, if you are off a little just remember coilovers are adjustable in ride height.Jack you're to good to me. Thank you for the compliments.
Going to be a sweet rig when you are done. Going to keep it powered by the 22re? Plenty of ways to still keep it low on leafs, there is a vendor on Pirate with low profile spring perches. You can install your rear shackle through the frame just like typical front leafs and french your front leaf spring mount. While they are cheap I tend to avoid Chevy and f150 springs that most use. When possible I like to use new springs. But if you are really tight on $ chevys do work for most.
Thanks for chiming in Brian. I have a lot of questions and I'm sure others I have not even thought about yet. What is a good number to look at for up travel with the axle set I will have? I'm not making a prerunner but would like to be able move at a decent speed over wash board roads and still have plenty of articulation. Maybe I could contact you by phone to discuss.Thanks,John
The HellFire front knuckles arrived 2 weeks ago so still need to get some parts to rebuild the front axle. Also not decided if running the stock birfields/axles or to get some Longfields or maybe the Nitro gear chromolys.
You would be fine to run the stock axles for a while. There is a chance that right away the Birfields might start clicking since the FJ80 was full time 4wd but you should be fine if you want to save a little $ and get Longs next year.
what do you plan on doing for steering up front?
I just received the HelllFire Hi Steer custom knuckles. I will be placing the tie rod under the arms to help with up travel. I also understand that I will have to use heims on the tie rod and drag link ends and move my steering box forward a little. That's the current plan.
Yeah im super excited!! Do u have any knuckle gusset sugestions or div covers?
I have been running a stock fj80 front with leaf springs and Hellfire Fab knuckles for 2 years now, a great setup. You can make mini truck knuckle ball gussets work and use any mini truck diff cover since the diff is still 8"
Updates?
Soo excited to see this build onfold. I was just in cahoots with Brian, to get my front link kit. I to have an fj80 front end with the hellfire knuckles. You will not be disappointed at all!
I know it sounds cheesy, but a dust mask and some good goggles go a long way when running a Metabo for hours at a time. Them floating metal particles will sneak into your eyes and lunges before quick could get ready and mess your party all up.
Started by ToyTech Parts For Sale
Started by twistedtoy92 « 1 2 ... 23 24 » Project Research and Build-Ups
Started by sricruiser Parts For Sale
Started by lbhsbz Parts For Sale
Started by Bazzi Transfer Case/Drive Line
