i think it would be best to move the rear axle back, especially if going with larger tires because under compression, the firewall in front of the doors is where vehicles usually rub, and where the front is at now, looks perfectalso, i think it would be easier to move the rear axle back than try to move the entire body forward
Those are some huge welds!
thanks for the smooch I miss you too !
i added 2 inches to all my links, no issues at all, just cut, sleeve, and reweld, done
neat truck gdunkleAnd you did nothing to your upper spring shock perch? what about the panhard? I can see if its just extending a couple inches possibly working but thats awesome if it actually does. Did you extend all links 2" or did you proportion the uppers and lowers longer?looking back threw the pics the last one shows the panhard already moving forward 1-1 1/2" so bringing it back should hurt
that axel is at best not square, at worse bent
Started by BirdDog Parts For Sale
Started by crawler925 Toyota Pickup/4Runner Tech 1979-95
Started by birfection Engine
Started by TangoJuliet Newbie Questions
Started by toy7521 Suspension
