Author Topic: EFI fuse blowing??  (Read 17252 times)
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
EFI fuse blowing??
« on: Dec 28, 2009, 07:56:30 PM »
A buddy has a 91 p/u 22re that is blowing the EFI fuse.  Basically, you can start it and it will go about 100 feet and "pop."  He has checked all the grounds.  He is not very good at mechanics, and I wish I was closer since I have been trying to diagnose it over the phone with him.
So, what are the top ten things to look for that would cause this?
I'm thinking he needs to pull the harness and start checking them with a volt/ohm meter.
And then onto all the injectors, sensors, and such.
What do you all think?
This all started all of the sudden.  Zero problems, then on the way home pop!
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • Member since Dec '06
  • NFM Customs
Re: EFI fuse blowing??
« Reply #1 on: Dec 28, 2009, 08:09:38 PM »
check the o2 sensor wires! I had the same problem back when i had my 89! it was just a wire that fell onto the exhaust pipe and was shorting out... popped the efi fuse about 3 times before i found it :biggthumpup:
86turboyota
  • Male Posts: 1,079
  • Member since Jul '05
« Reply #2 on: Dec 28, 2009, 08:12:19 PM »
i had the same problem but mine turned out to be the fuel pump.
My Build 1986 4runner SAS 36s etc
http://board.marlincrawler.com/index.php?topic=22625.0
"Later, I learned that even though I engage 4WD my hubs are not automatically locking? Something about manual locking hubs I think. What's manual mean? I need to read a manual to lock them? lol  So I found these neat autolocking hubs and installed them. Sometimes they dont stay locked while I am backing up, but that's fine because I dont have a backup camera to see where Im going (like our RV) so I just simply dont ever back up"- BigMike
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
« Reply #3 on: Dec 28, 2009, 08:52:06 PM »
x2 on the O/2 sensor wire.  Mine melted to the exhaust pipe and was shorting out.
Quote
lax815
  • Male Posts: 49
  • Member since Jul '08
« Reply #4 on: Dec 28, 2009, 09:05:08 PM »
Had that happen to me a few weeks ago on my 91 3vze - it was the fuel pump.
Every thing was going good as I was accelerating uphill and it cut out suddenly and wouldn't start again.
Blown EFI 15A fuse and the old pump didn't turn with 12V on it  - didn't try a new fuse though, just replaced it and the pump (216000mi on the clock).
- Michael
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
  • Member since Jun '07
    • Buy me a drink
« Reply #5 on: Dec 28, 2009, 09:06:31 PM »
x3 had it happen many times!
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
« Reply #6 on: Dec 28, 2009, 09:14:04 PM »
lol yea i have the same friend....  hmm one of us is gona have to get with em and take a look at it... start jiggling some wires, has to be a ground (or lack there of)
Those are some huge welds!
Tillamook, OR
  • Turtle Points: 679
  • Member since Feb '03
  • Don't blame me, I didn't vote for this crap.
« Reply #7 on: Dec 28, 2009, 10:31:57 PM »
I chased and chased the same issue for a loong time about 4 years ago.  Sometimes the fuse would last a minute, sometimes a week.  I finally got pissed off headed home after a long graveyard shift and put a couple male disconnects on a short piece of wire.  Been that way ever since. :talkingn:
83 Crawler
  • Turtle Points: -13
  • Male Posts: 2,779
  • Member since Jun '09
« Reply #8 on: Dec 30, 2009, 07:42:13 AM »
X3!!!!!! 89sastoy when threw the same problem and it was the o2
MC387
  • Turtle Points: -4
« Reply #9 on: Dec 31, 2009, 09:50:24 AM »
Looks like that fuse supplies the Fuel pump, the ecu, Both 02 sensors, And the Air flow meter.  It also goes to the check connector.
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #10 on: Dec 31, 2009, 11:49:14 AM »
there ya go... check all the wires and make sure they haven't shorted out.
swapped89
  • Turtle Points: 270
  • Male Posts: 1,221
  • Member since Aug '09
  • Not all who wander...are lost
« Reply #11 on: Dec 31, 2009, 12:06:41 PM »
same thing happened to me. o2 wires were melted and grounding on the exhaust by the cat.
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
2manytoys
  • Turtle Points: 490
  • Male Posts: 583
  • Member since Nov '09
« Reply #12 on: Dec 31, 2009, 12:08:57 PM »
Another vote for the O2 sensor wire. Happened on my kids 91 22RE. Was intermittent. When ever it happend to touch the exhaust it blew the fuse.
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
« Reply #13 on: Dec 31, 2009, 01:41:37 PM »
everyone is sayn the 02 is this the one on the downpipe,   i remember one of my 22rs had one down by the trans also, could that be the one grounding or do they even have one on a 22re
Tillamook, OR
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
« Reply #14 on: Dec 31, 2009, 02:00:07 PM »
The one by the cat is the one everyone is talking about.
Quote
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #15 on: Dec 31, 2009, 07:33:56 PM »
yes, down by the cat.... (if you have a cat still)  :psss:   :_oops:
crawlnbeaver
  • Male Posts: 19
« Reply #16 on: May 25, 2011, 12:31:13 PM »
it was the o2 on mine also... thanks everyone :)
Last post Mar 06, 2005, 08:15:46 AM
by DeMented Toys
Last post Feb 14, 2012, 09:56:23 PM
by Bobby Hunter
Last post Oct 20, 2013, 11:21:03 AM
by Nation
Last post Dec 09, 2013, 11:18:01 AM
by Plowking
Last post Feb 22, 2014, 01:41:58 PM
by megaphoneman
