Author Topic: anything you have FABBED  (Read 116501 times)
John Doe
  • Turtle Points: 469
  • Male Posts: 1,587
  • Member since Jun '05
    • Bored In Iraq.
Re: anything you have FABBED
« Reply #120 on: Mar 10, 2011, 06:17:54 PM »
I saved these drawers from the dumpster/ scrap bin and made a nice rack for them...
once I find a space, it will get mounted on the wall and a bar across the bottom will be added for shop towels.
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
  • Member since Oct '06
« Reply #121 on: Mar 10, 2011, 07:20:30 PM »
thats sweet,
I need something like that in the garage,
:pokinit: gets soo cluttered it takes more time finding :pokinit: than actually working
4LoRunner
  • Turtle Points: -13
  • Male Posts: 680
  • Member since Dec '08
  • 109:1
    • Loaded Defense
    • Buy me a soda
« Reply #122 on: Mar 10, 2011, 08:49:01 PM »
very nice i like that alot hmmm might have to copy you if you dont mind
Sas'd '86 4Runner, 22RE-T, 4.88s, Dual Stock T-Cases, Locked F/R, 35" MTR's.
http://board.marlincrawler.com/index.php?topic=55751.0
John Doe
  • Male Posts: 1,587
    • Bored In Iraq.
« Reply #123 on: Mar 10, 2011, 09:55:08 PM »
Go ahead, my patent hasnt gone through yet
4LoRunner
  • Male Posts: 680
  • 109:1
    • Loaded Defense
    • Buy me a soda
« Reply #124 on: Mar 11, 2011, 05:11:50 AM »
haha well someone give me a welder first then i will
golana
  • Turtle Points: 45
  • Male Posts: 112
  • Member since Mar '11
  • The Crazy One
    • analog OffRoad
« Reply #125 on: Mar 15, 2011, 10:14:07 AM »
started out as a stock 85 4x4 lifted 3"
22re to 5vz-fe post-filter fuel line
cut the banjo end off the line, and used the 5vz-fe fitting
onboard air compressor bracket for 22re
uses a Sanden 508 compressor and bolts to the stock toyota a/c bracket
first custom bumper (horrible haha)
in-cab winch controller
riveted it to the cluster bezel. flick the switch to activate the rocker switch. LED lights up when the switch is active
power distribution block
countersunk the bolt heads
after smashing out all my markers and stuff with the tube bumper, i decided to build a solid one
got a bit too close with the edge of it after making a long pass with my welder haha
my mini-fab shop (after hours fabrication)
needed more flex capability in the front... sqtube driveshaft was needed
cut up an old, rotted out tank for the mounts
layed them down on the fuel cell i built a couple years ago
marked and cut out where i wanted them
cut out the old chevy pump mount and welded my toy one up
painted it (the bottom side turned out so much better though)
brake line dropper
installed
custom lift shackles. i used 2 pieces of C channel and my 40ton press to bend these
installed (did rears too)
needed rear caliper mounts for rear disc!
if i could do one thing different, i wouldnt put that big inspection cap on the diff... though i may have finally solved the leaking issue now...
traded one of my s10's for a doubler setup haha
started fabbing up a flat crossmember for my doubler setup
did a 3.4L swap recently
built a cowl hood instead of a body lift, or a hood scoop!
im working on a trans-brake now for an ebrake, cause with rear disc, i dont have an ebrake anymore...
ive done lots since, but i started making videos instead of taking pictures haha! enjoy!
« Last Edit: Mar 15, 2011, 10:21:29 AM by golana »
-Steve
1994 4Runner - BUILD THREAD
5VZ-FE - 12" Lift - High Steer - Hydraulic Assist - IFS Mod - Scuba Mod - Ford Fuel Tank - E-Fan - Doubler = 96.31:1 Crawl Ratio
Brake setup
FRONT: 98 Tacoma Rotors/Brake Master Cylinder/Booster, 94 V6 Pickup Calipers, 86 IFS Hubs
REAR: 85 Solid axle Rotors/Calipers/Lug Studs, 1/4" Wheel Spacer
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Member since Nov '04
  • Drinking me beer
« Reply #126 on: Mar 15, 2011, 11:15:52 AM »
I made this not too long ago
Talon84x4
  • Turtle Points: 375
  • Male Posts: 919
  • Member since Mar '06
« Reply #127 on: Mar 15, 2011, 11:34:36 AM »
That's pretty cool, did you use a forge for the vines or torch
Low & Slow 84 PU - http://board.marlincrawler.com/index.php?topic=31982.0
Central Valley Crawlers
junya92toy
  • Male Posts: 1,500
  • Drinking me beer
« Reply #128 on: Mar 15, 2011, 11:45:37 AM »
I have a forge.
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
  • Member since Sep '09
    • Poly Goats
« Reply #129 on: Mar 15, 2011, 01:14:26 PM »
You need to start a build thread!  :talkingn:
Any more info on the rear disk setup? I've seen your posts on pirate before and always like how you did everything yourself  :thumbs:
golana
  • Turtle Points: 45
  • Male Posts: 112
  • The Crazy One
    • analog OffRoad
« Reply #130 on: Mar 15, 2011, 06:33:45 PM »
I should start a build thread :) that would be awesome! I have a big build thread over at my once local website haha! I should start one here too! I love getting input and ideas for my builds :) once I get on my computer at my house, ill start a thread :)
-Steve
Brake setup
golana
  • Turtle Points: 45
  • Male Posts: 112
  • The Crazy One
    • analog OffRoad
« Reply #131 on: Mar 15, 2011, 07:22:11 PM »
I have all the info you could want :) I did the IFS mod on the front. I used 98 rotors, 94 calipers, 88 hubs. For the rear, I used the 85 rotors, 85 calipers, and my custom brackets. Ill post detailed pictures and info in the build thread I'm going to start :)
-Steve
Brake setup
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
    • Poly Goats
« Reply #132 on: Mar 15, 2011, 08:33:32 PM »
Can't wait! I'm thinking about doing the ifs hub/taco brakes and rear disks with the s/a rotors and calipers too. How do you like the set up?
golana
  • Turtle Points: 45
  • Male Posts: 112
  • The Crazy One
    • analog OffRoad
« Reply #133 on: Mar 15, 2011, 09:54:50 PM »
I freaking love the setup haha! I had a bit of an accident with my truck so I'm driving my brother's 4runner. Going back to drum brakes sucks big time! I need a prop valve though, cause the rear locks up before the fronts.
-Steve
Brake setup
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
    • Poly Goats
« Reply #134 on: Mar 15, 2011, 10:30:33 PM »
Did you basically do the same thing as the fror kit?
golana
  • Turtle Points: 45
  • Male Posts: 112
  • The Crazy One
    • analog OffRoad
« Reply #135 on: Mar 15, 2011, 10:43:02 PM »
I don't know what that is...
-Steve
Brake setup
golana
  • Turtle Points: 45
  • Male Posts: 112
  • The Crazy One
    • analog OffRoad
« Reply #137 on: Mar 15, 2011, 11:39:41 PM »
http://frontrangeoffroadfab.com/nfoscomm/catalog/product_info.php?products_id=136&osCsid=87f97c6a1ab4c0
nope... i didnt machine anything, or use any special parts... i built it with what i had laying around... i used 94 v6 calipers off a parts truck we had... they had the 4 big pistons inside the caliper. the solid axle calipers i used on the back have 2 big pistons and 2 small pistons in each caliper... the only tacoma parts i used were the rotors...
it was super easy to do this mod... i drilled out the steering knuckle stock caliper mounts to 1/2". on the calipers, i just used a 1/2" tap to tap the holes for a 1/2" bolt. i used grade 8 hardware. ill do a detailed writeup if anyone is interested :)
-Steve
Brake setup
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
« Reply #138 on: Mar 15, 2011, 11:46:25 PM »
please do
golana
  • Turtle Points: 45
  • Male Posts: 112
  • The Crazy One
    • analog OffRoad
« Reply #139 on: Mar 15, 2011, 11:47:48 PM »
haha, will do :) ill do it up as soon as i get my build thread all situated :)
-Steve
Brake setup
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
    • Poly Goats
« Reply #140 on: Mar 16, 2011, 12:17:16 AM »
Can't wait  :clap:
golana
  • Turtle Points: 45
  • Male Posts: 112
  • The Crazy One
    • analog OffRoad
-Steve
Brake setup
Zs Confederate Toy
  • Turtle Points: 2
  • Male Posts: 1,146
« Reply #142 on: Apr 12, 2011, 08:00:54 PM »
Its nothin special, but Im pretty proud of it lol. Its a Hi Lift mount. I think Im gonna scrap it and make one that goes on the top of my tailgate.
I started with this
Cut it into 2x2 squares and welded them back together on the sides
Buzzed onto the bed
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
junya92toy
  • Male Posts: 1,500
  • Drinking me beer
« Reply #143 on: Apr 12, 2011, 08:11:38 PM »
I hand forged the legs, tapered the ends and did the scrolls. Made the frame, and used marble tile for the top.
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
    • Poly Goats
« Reply #144 on: Apr 12, 2011, 09:06:11 PM »
 :clap2: Impressive, nice work.
John Doe
  • Male Posts: 1,587
    • Bored In Iraq.
« Reply #145 on: Apr 12, 2011, 09:38:37 PM »
My welding cart. I have just a few small things left.
Jaysen
  • Turtle Points: -20
  • Male Posts: 773
  • Member since Mar '08
« Reply #146 on: Apr 12, 2011, 10:06:04 PM »
that hella pimp  :moon: cart! javascript:moreSmileys();
95 22RE. Toyota Ext.Cab SAS. Dual Case.
1988 Honda Civic 4dr lx,
2007 Honda Ruckus scooter
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
« Reply #147 on: Apr 20, 2011, 04:07:07 PM »
Some brush holders so we can run more efficiently.  Each brush $70. (50 total, both sides), all stainless baby!
Missing brush, fell to its doom.
Zs Confederate Toy
  • Turtle Points: 2
  • Male Posts: 1,146
« Reply #148 on: Apr 20, 2011, 04:57:35 PM »
I don't know what Im lookin at here. Can you expand on it please?
ZACH
87 Rock Rat X
Trail Junky
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
« Reply #149 on: Apr 20, 2011, 07:12:37 PM »
Sorry, thought it was cool because it saves alot of time on my part.  The brushes transmit power through a commutator ring.  If you need power through a moving object then this is the way to do it.  The rotating machinery uses a set of U shaped slip rings, and the brushes make contact inside that U transmitting power or whatever, through that contact.  Rings and brushes in last picture.  I'll take pics of the old set-up, so you can get an idea.
Last post Dec 08, 2005, 02:00:15 PM
by Duffil
Last post Sep 24, 2006, 01:56:32 PM
by ga-toy
