Author Topic: installing CB / anteni  (Read 28512 times)
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Member since Apr '05
  • Broke & rusted
    • myspace
« on: May 07, 2008, 05:58:35 PM »
Well i decided to clean the shed and i found my old cobra 25 LTD.  So i went 2 the Cb shop had them check the radio out ( been siting 12yrs )  also picked up a 3ft firestick  and a mount and 18' of coax  for  55$
I decided 2 mount it batween the cab and box  and this required some modification  :flamer:
« Last Edit: May 11, 2008, 01:27:29 PM by unclejpl4x4 »
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: installing Cb / anteni
« Reply #1 on: May 07, 2008, 06:01:13 PM »
i thought you had a cobra 21  :headscratch:
Lady Di
  • Goddess of Mud
  • Internet Lassies
  • Female Posts: 299
  • Member since Nov '04
« Reply #2 on: May 07, 2008, 06:08:22 PM »
:psss: Cb?  you mean CB? and Anteni... is that a hot Italian actor?
And why is there a polar bear scratching his head?
JK! :rofl: Carrion!
Life is like a bowl of beer flavored chocolate covered dog turds.. it makes no sense. :pokinit:
Where is the Mammoth?
How the Mammoth came to be
Number Two :pokinit:
unclejpl4x4 [OP]
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #3 on: May 07, 2008, 06:08:58 PM »
Now  I took apart the whole dash trying 2 find a place 2 stick the 25  :_order:   No good
My buddy gave me a bra new in the box  cobra 21---- well if you can consider that new.
Now i am anal when it comes 2 a clean cab/install i think im gona mount the 21 under the radio.
here are some more pics  get more 2marrow darn sun went 2 sleep
The first pick i took the cut off tool and trimmed some metal and yanked out the foot heater tube  :cheese:
and yes that dark spot on the right side under the CB is where i melted the carpet  :hammerhead:
« Last Edit: May 11, 2008, 01:28:04 PM by unclejpl4x4 »
unclejpl4x4 [OP]
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
Re: installing CB / anteni
« Reply #4 on: May 08, 2008, 10:32:15 AM »
Ok suns out time for CB insulation
So with the dash apart  time 2 pull out the radio.  This is where i separated the front 2 plates for cutting.
I used a air cutoff wheel   bench grinder and hand file.   Using the CB as a template i marked and cut  then filed till i had a nice fit.
Note: Do not use 2 much pressure or you will break the metal like i did then have 2 weld it.
Note: becareful not 2 damage the outside cover when cuting.
Now i got run 2 the hardware Store for metal so i can mount the BC 2 the dash brakets.
Dr.Maxwe001
  • Turtle Points: -23
  • Male Posts: 627
  • Member since Jan '05
« Reply #5 on: May 08, 2008, 10:39:23 AM »
 :headscratch: umm wouldnt it have been easier and quicker to  get a magnetic mount atena and just stick the Cb under the driver side seat next to the shifter   :dunno:
[img]http://bo
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #6 on: May 08, 2008, 10:42:21 AM »
You missed this part>>
Now i am anal when it comes 2 a clean cab/install :moon:
Do you have a dartboard in your shed joe? what else u hiding in there? :eye:
Quote
unclejpl4x4 [OP]
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #7 on: May 08, 2008, 05:06:20 PM »
I did not get much done 2day  :down:  here are some brackets i bent-up  + the speaker   I got go get some screws .
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
  • Member since Dec '06
« Reply #8 on: May 08, 2008, 07:23:48 PM »
This is looking pretty nice. Keep it up!
unclejpl4x4 [OP]
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #9 on: May 11, 2008, 12:54:33 PM »
Ok shes done :thud:    I ran in 2 a problem and had 2 get a new CD/stereo and also picked up the adapter for the outer space radio  so $140  i did not wanna spend.
I had 2 cut more of the dash then i wanted 2  :willynilly:
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
  • Member since Jun '07
    • Buy me a drink
« Reply #10 on: May 11, 2008, 01:03:09 PM »
pretty sweet dude.
« Reply #11 on: May 11, 2008, 01:18:55 PM »
looks good, i cant mount my cb  there,  darn first gens :snare:
« Reply #12 on: May 11, 2008, 01:22:06 PM »
so when can i expect  the cobra 29  in the mail  :disturbed:
unclejpl4x4 [OP]
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #13 on: May 11, 2008, 01:26:00 PM »
I am having a problem with static feedback threw the external speaker when the CB is off ( everything off radio,truck )
 i  got a arc when installing the assembly but the ground was not hooked up/ key was on ACC   so the radio was looking for a ground.
I check all the wires i could see and i see no chafed power or speaker wires.   I soldered all the wires/heat shrink.
But if i unplug the mic it gose away   or pug in the mic from the cobra 25   but that has it's own problems.  Im gona pick up a cobra   http://www.cobra.com/index.cfm?fuseaction=product.display&Product_ID=75&category_ID=34
unclejpl4x4 [OP]
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #14 on: May 11, 2008, 01:27:10 PM »
ya cobra 25 ltd classic  i must of been :smoke: that day.
« Reply #15 on: May 11, 2008, 03:18:20 PM »
:headscratch:
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #16 on: May 11, 2008, 03:27:57 PM »
:dunno: don't ask me, I think hes a little :screwy: or maybe :boozer:
Dr.Maxwe001
  • Male Posts: 627
« Reply #17 on: May 12, 2008, 06:09:58 AM »
he's not a little  :screwy: he is alot :screwy: and thats not all he is alot  :stopit: too
[img]http://bo
PA_taco_13
  • Male Posts: 309
  • Member since Dec '05
  • PA Muddin
« Reply #18 on: Dec 19, 2009, 04:00:36 PM »
looks nice joe!     :thumbs:   hope mine turns out the same
learn the hard way
"my dixie wrecked"
east coast crawler
PA_taco_13
  • Male Posts: 309
  • PA Muddin
« Reply #19 on: Dec 19, 2009, 05:16:49 PM »
Hey Joe, I notice that your CB sticks out just a little bit.  And here is a picture of my one buddy's cb install.  His sticks out quite a bit.  He said his sticks out because of the way his cables hook up.  Did you have that problem?
learn the hard way
"my dixie wrecked"
east coast crawler
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Drinking me beer
« Reply #20 on: Dec 19, 2009, 05:55:09 PM »
Mines the same way Brian.
b-radhutch
  • Member since Aug '09
  • my first yota
« Reply #21 on: Dec 19, 2009, 06:14:56 PM »
the CB unclejpl4x4 put in is shorter and has less nobbs so im asuming that your CB could be longer?
unclejpl4x4 [OP]
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #22 on: Dec 19, 2009, 07:10:34 PM »
ya  the cobra 25s are big    thats why i got the 21 shorter smaller..........    i suggest before you hack the dash  to find a good high quality/output compact   and not a behemoth  like the one in the pic :boobs:
reddevil500
  • Turtle Points: -1
  • Male Posts: 45
  • Member since Dec '09
  • T O Y O T A lasts forever!
    • I Dreamt About Her!
« Reply #23 on: Dec 19, 2009, 07:22:01 PM »
is there a specific way to talk to somebody on the CB when your say in trouble o you just go for it as if were a phone?
Craigslist!
b-radhutch
  • my first yota
« Reply #24 on: Dec 19, 2009, 07:27:56 PM »
channel 9 if i rember is emergency i have the 25 channel cb from cobra more than 15 years old
reddevil500
  • Turtle Points: -1
  • Male Posts: 45
« Reply #25 on: Dec 19, 2009, 07:32:56 PM »
yeah but you just start hollering for help (I need help stranded flipped over on so and so trail about so so miles Northwest from so and so) example?
Craigslist!
b-radhutch
  • my first yota
« Reply #26 on: Dec 19, 2009, 07:49:17 PM »
not sure never had to do it
reddevil500
  • Turtle Points: -1
  • Male Posts: 45
« Reply #27 on: Dec 19, 2009, 07:51:17 PM »
i guess thats a good thing!
Craigslist!
b-radhutch
  • my first yota
« Reply #28 on: Dec 19, 2009, 07:55:48 PM »
i guess so lol try posting a topic hb it in CB / Ham radio tech
reddevil500
  • Turtle Points: -1
  • Male Posts: 45
« Reply #29 on: Dec 19, 2009, 07:57:04 PM »
will do, good looking out!
Craigslist!
Last post Feb 12, 2004, 12:17:16 AM
by WHITE_TRASH
Last post Mar 30, 2005, 11:50:45 AM
by BLACKDOG
Last post Apr 24, 2011, 10:16:43 PM
by 85_yote_94
Last post Jul 25, 2007, 01:11:57 PM
by MiniSimp
Last post Sep 19, 2008, 02:12:53 PM
by taco522
