Author Topic: OBA setup with superflow comp.  (Read 3966 times)
Yota4life
  • Turtle Points: -128
  • Male Posts: 1,461
  • Member since Nov '04
« on: Mar 09, 2006, 07:10:10 PM »
Im almost done with the set up. I wanted to have OBA for airing up my 36" iroks after hitting the trail. Also for the occasional use of air tools and soon for activating an ARB locker. I didnt want to spend to much but also have a pretty quick setup.
I found a Superflow MV50 air compressor on ebay for 60$. Heard pepboys used to sell them for around 25$ They put out 2.54 CFM and are the best bang for the buck i could find. Mounted under the hood hardwired to a switch in the cab. Ran a one way check valve to a 1-3 manifold with PSI gauge. Mounted a 2.5 gal. tank from onboardair.com above the rear axle under the bed. Ran one coupler by the front bumper and one out by the back bumper for air hose hook up. I will post pics of the whole set up soon and time how long it takes to air 1 tire up. I still need to buy a pressure switch to splice into the MV50s power. A 85psi on/105psi off should be good.
Heres a couple write-ups on the MV50
http://www.parksoffroad.com/miscinstalls/inflatortest/mv50/mv50.htm
http://www.moabjeeper.com/superflow.htm
Cost
Superflow compressor     60$
Tank                             55$
Fittings,man.,gauge         60$
50ft air hose                   22$
Couplers                         16$
TOTAL                        $213.00
« Last Edit: Mar 10, 2006, 10:16:01 AM by Yota4life »
Vic stuff
  • Turtle Points: 52
  • Male Posts: 172
  • Member since Jan '06
  • Damn it feels good to be a gangsta.
    • XT Offroad
Re: OBA setup with superflow comp.
« Reply #1 on: Mar 09, 2006, 08:35:15 PM »
 :worthless:
84 4Runner - 37's, Locked F/R, 4:1 (single), Cab exo, new front bumper and some more tubage coming soon! Currently parked with a blown motor :(
05 Explorer - The Wife Mobile
04 Chevy Silverado - Towrig/DD
Yota4life [OP]
  • Male Posts: 1,461
« Reply #2 on: Mar 14, 2006, 08:01:57 PM »
Ok i got everything finished up. Today i hooked up the pressure switch its a 85psi on/ 115psi off, cost 23$ from central. I ran 2, 3-1 manifolds together so i have one open spot that i put a plug in for now. That will be where i run my arb off of a little later.
I used the set up on saturday to air back up and it took over 20 minutes to air back up from 8-25 PSI. To make the process faster im going to buy a 4air system from 4crawler http://www.4crawler.com/4x4/ForSale/4air.shtml
Heres some pictures
Yota4life [OP]
  • Male Posts: 1,461
« Reply #3 on: Mar 14, 2006, 08:05:59 PM »
2.5 gal tank from onboardair.com
Used a drain thingy on the bottom to empty any moisture build up or if the pressure switch stops working. Ran one line to the comp. and the other goes to a couple on the rear bumper.
Yota4life [OP]
  • Male Posts: 1,461
« Reply #4 on: Mar 14, 2006, 08:10:18 PM »
I know i can probley hit this on a rock, im going to move it in a safer place around the bumper but it stays here for now
Yota4life [OP]
  • Male Posts: 1,461
« Reply #5 on: Mar 14, 2006, 08:12:42 PM »
Another shot, you can see the relay under it. The pressure switch was wired into the relays ground. Theres the in-cab switch wired and ON...
Yota4life [OP]
  • Male Posts: 1,461
« Reply #6 on: Mar 14, 2006, 08:16:30 PM »
Front coupler. It will also be moved to the top of the bumper where the winch mount is. Once i get the winch mounted i will move the coupler.
If you have any questions about the set up let me know what you think.
IronClad
  • Turtle Points: 635
  • Male Posts: 2,284
  • Member since Feb '05
  • Annihilation Fabrication
« Reply #7 on: Mar 14, 2006, 08:18:02 PM »
how long does it take to air up all yer tires ?
Do you need a Hammer?
Yota4life [OP]
  • Male Posts: 1,461
« Reply #8 on: Mar 14, 2006, 09:13:23 PM »
About 20 minutes. Im not exact because i havent timed it yet.
IronClad
  • Male Posts: 2,284
« Reply #9 on: Mar 15, 2006, 01:40:06 PM »
damn thats a long time :\
skid
  • Turtle Points: 144
  • Male Posts: 295
  • Member since Oct '04
« Reply #10 on: Mar 15, 2006, 01:55:30 PM »
Been using a setup like that for the last year.  Bought a 7 gallon tank from Walmart for $20.    Keeps up with a friends arb compressor.   Only thing is, mine doesn't like to start with pressure on the pump.  60+ lbs and it will pop a fuse.  I plumbed in a valve to get around this.
Diggin a hole with plastic
90 ext cab toy, short 40 Iroks, detroit and diamond, mco8-r10 duals with twin stick, 4.7 gears and 30 spline Longs/hub gears-studs
Yota4life [OP]
  • Male Posts: 1,461
« Reply #11 on: Mar 15, 2006, 05:42:48 PM »
I ran a one way check valve also. Ya it does take some time to air up,they are 36" tires though.... but for a 60$ comp its worth it. One day i might go with a faster compressor or get a powertank for airing the tires up. To buy a quickair thats as fast its almost 200$
IronClad
  • Male Posts: 2,284
« Reply #12 on: Mar 15, 2006, 06:09:45 PM »
i run a  stock toyota AC compressor i got for 10 bucks  to a tank and it takes me 5 mins from the time i hit the switch  to air up all 4 of my 38s .... :\  i think i have like.. 15 bucks in my whole OBA setup.   somthin to look into...   i dont like the power tanks  or running co2  because once it goes empty.. its empty
Skinny_Pedal
  • Turtle Points: 89
  • Male Posts: 2,833
  • Member since Apr '04
  • work so I can support my lifestyle
« Reply #13 on: Mar 15, 2006, 08:12:57 PM »
15 bucks seems a little cheap. you clearly had parts lying around which im sure dont. or your not running an oiling system, theres a cheaper way to set it up. if i were to run a toy compressor i would be sure to carry a spare because if they don't get enough oil there toast. but when working properly they air tires up fawking quick
Im an OG
IronClad
  • Male Posts: 2,284
« Reply #14 on: Mar 15, 2006, 08:23:07 PM »
only thing i had laying around was the tank and the hose and hose clamps ( already had a hose )  my engine came with a ac pump but i burnt it up because i forgot to oil it one night and i aired up 4 trucks worth of tires from 5 psi or less to street pressure.
   bought another for 10 bucks and i spent like 5 bucks on a air fitting to run the hose i had off the tank  .  wire up a switch to hot  plumb to the tank and bam  done.  right now i just put in a teaspoon of oil  about every other time i use it or unless im airing up a bunch of people i do it then. dont have my oil seperator yet  and  im going to find a windshield washer bottle + motor and hook it up to feed oil into my pump easily.
tanks are easy to come by.. hell you could probably make one out of a old propane tank..  seen it done once before i believe.
theres some toy ac pumps that bolt right into smog pump brackets  cant remember which one  but that makes it so you dont have to build brackets.
Yota4life [OP]
  • Male Posts: 1,461
« Reply #15 on: Mar 16, 2006, 08:17:21 AM »
I would like to go that direction with the ac pump, but i dont have ac in my truck. So i would need a list of parts and a bracket to mount it to. Could you right out a list of needed parts?
derek
  • Turtle Points: -61
  • Male Posts: 600
  • slow truck=more time to nap
« Reply #16 on: Mar 16, 2006, 11:27:37 AM »
i have been running the same stock toy compressor for 2 years now. have not burnt it up yet.
i just dump some slick 50 in the intake when i think about it, about every 6 months or so.
airs up tires fast and runs my arb.
derek
CTENG in KS
  • Turtle Points: -501
  • Male Posts: 4,295
  • Member since Jun '04
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #17 on: Mar 16, 2006, 11:30:27 AM »
Anybody know if Front Range still sells their ac conversion kit?  That would have had everything you need but the tank.
burnyota
  • Turtle Points: -36
  • Male Posts: 567
  • Member since Mar '04
    • BURNYOTA
« Reply #18 on: Mar 16, 2006, 11:45:44 AM »
little bit more $$$ when you can scroung up what u need for cheepo
ryan
85 p/u, marlin#208, built 22R on propane, old school longs, 5.29's / detroits, bobbed, chopped, and flopped
CTENG in KS
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #19 on: Mar 16, 2006, 12:03:02 PM »
I was looking for the webpage as a guide to what you need, but I don't think FROR offers the kit anymore.   :dunno:
HEY MARLIN!
derek
  • Male Posts: 600
« Reply #20 on: Mar 16, 2006, 02:55:36 PM »
i just went to harbor freight and got all the parts i needed, bought way more stuff than i needed, but live and learn.  :hammer:
derek
Yota4life [OP]
  • Male Posts: 1,461
« Reply #21 on: Mar 16, 2006, 10:26:34 PM »
I know you need some extra little parts to add to the ac system but im saying what do i need to start with? Do i just need a belt,ac pump bracket, and the ac pump its self and a little wiring and plumbing? I have to start from scratch. Tell me all you know
Last post Jan 18, 2004, 08:23:56 PM
by booger weldz
Last post Aug 03, 2005, 10:09:40 PM
by Crucial
Last post Sep 04, 2005, 05:38:56 PM
by wa4x4
Last post Oct 14, 2005, 10:51:14 AM
by 92yota
Last post Oct 01, 2007, 06:11:50 AM
by Slobbermouth
