Author Topic: Links to FAQs and Information  (Read 56560 times)
colsoncj
  • Turtle Points: 124
  • Male Posts: 101
  • Member since Dec '05
  • Need more money for more mods
« on: Jan 03, 2006, 12:18:45 PM »
This Thread is Featured in our Tech from our Forum Members section!
Updated 3/13/09
Well I got tired of looking through several threads to find the thread I wanted, so I started a list of links to FAQ's and info about various things... Since its all nicely compiled I figured I'd share it.  Hope this helps some of ya!
I'll keep adding to it, if I find more, and if theres some things that some of you know about, post them and I'll add them in!
General Toyota FAQ's:
.......... http://www.pirate4x4.com/forum/showthread.php?t=459180
.......... http://www.yotatech.com/~corey/tech/techpage.htm
.......... http://www.yotatech.com/~corey/4runner_faq.htm
.......... http://www.yotatech.com/showthread.php?t=66255
Online FSMs
.......... http://www.ncttora.com/fsm/
.......... http://www.4x4wire.com/forums/showflat.php?Cat=&Number=752426
AXLES:
Comparisons: http://www.pirate4x4.com/tech/bible/index.html
.......... http://home.4x4wire.com/erik/diffs
TOYOTA 8": http://www.4crawler.com/4x4/CheapTricks/AxleTech/index.shtml
.......... Rebuilding Info: http://www.4x4wire.com/toyota/maintenance/front_end/solid_axle/
.......... .......... http://www.4x4wire.com/toyota/maintenance/front_end/teardown/
.......... .......... http://www.4x4wire.com/toyota/maintenance/front_end/solid_axle/
.......... .......... http://www.4crawler.com/4x4/CheapTricks/AxleRebuild.shtml
.......... .......... http://www.4x4wire.com/toyota/tech/gear_setup/
.......... .......... http://www.pirate4x4.com/forum/showthread.php?t=281879
Toyota Component Strengths (D44/D60 too): http://www.pirate4x4.com/forum/showthread.php?t=350905
D44's: http://www.4x4wire.com/forums/showflat.php?Cat=&Number=255906&page=3&view=collapsed&sb=5&o=&fpart=1.
D60's: http://www.pirate4x4.com/tech/billavista/60_front/index.html
D70's: http://www.pirate4x4.com/tech/billavista/D70/D70.htm
14 bolt: http://www.pirate4x4.com/tech/billavista/14b_bible/index.html
Hybrids: http://www.pirate4x4.com/tech/billavista/Hybrid_Axle/HybridAxle.htm
Rockwells: http://www.pirate4x4.com/forum/showthread.php?t=313836
.......... http://www.jpmagazine.com/techarticles/154_0305_ton/index.html
.......... http://www.fourwheeler.com/techarticles/77419/
Lockers:
.......... Toyota 8" Air: http://www.4x4wire.com/toyota/tech/arb_locker/
.......... Toyota IFS Air: http://www.4x4wire.com/toyota/4Runner/tech/ifs_airlocker/
Stock Toyota Engine Improvements and Info:
20R/22R: http://ttora.com/forum/showthread.php?t=84715
22R to 22RE Conversion: http://pirate4x4.com/forum/showthread.php?t=316661
22RE: http://www.4x4wire.com/forums/showflat.php?Cat=&Number=820891&page=&view=&sb=5&o=&fpart=1&vc=1
22RE Superchargers: http://www.toyotacatalog.net/M1WebGear/ProductDetails.aspx?PartUniqueID=F7EF392E-DC95-44A2-AC8F-E6DF0C03E232
Engine Swaps into Toyotas:
General: http://www.mindspring.com/~jayk3/toyota/swaps.htm
.......... http://www.pirate4x4.com/forum/showthread.php?s=&threadid=175795
Buick 231: http://www.off-road.com/toyota/buick_v6_swap.html
Chevy 4.3:  http://www.off-road.com/toyota/tech/other/v6swap.html
Chevy 350:
Ford 302/351: http://www.yotatech.com/showthread.php?t=72065
Toyota 3.4 V6: http://www.yotatech.com/showthread.php?t=82145
.......... http://www.yotatech.com/showthread.php?t=81553
.......... http://board.marlincrawler.com/index.php?PHPSESSID=840f8d4a224d3d9795cbe80eccb90642&topic=19684.0
.......... http://www.andrewzook.com/content/view/22/37/
Toyota 22R to 22RE: http://www.yotatech.com/f115/22r-22re-swap-129693/
Toyota 5M/7M: http://www.4x4wire.com/toyota/tech/supra/
.......... http://4x4.4t.com/4runner/7mswap.htm
.......... http://www.off-road.com/toyota/tech/supraswap/
.......... http://www.supracharged.com/forum/viewtopic.php?t=298
Toyota V8: http://www.yotatech.com/showthread.php?t=54771
Toyota Diesel (1KZ-TE):  http://www.yotatech.com/showthread.php?t=77103
Transfer Cases:
Double Toy Cases: http://www.fourwheeler.com/techarticles/129_0207_case/index.html
.......... http://www.marlincrawler.com/docs/dualcase/install.html
Double NP Cases: http://medusa.ih8mud.com/NP205/Doubler.html
.......... http://www.offroaddesign.com/catalog/doubler.htm
Toy Cases Info: http://www.fourwheeler.com/techarticles/129_0207_case/index.html
.......... http://www.off-roadweb.com/tech/0607or_toyota_transfer_case_upgrades/index.html
NP Cases Info: http://www.off-road.com/chevy/tech/transfercaseguide/
Suspensions\Lifts:
SASing:  http://www.yotatech.com/showthread.php?t=73430
.......... http://www.yotatech.com/showthread.php?t=73882
.......... http://www.tacomaterritory.com/forum/forumdisplay.php?f=7
.......... http://www.toyotaoffroad.com/Articles/Projects/Snorkleman_SAS/Snorkleman_SAS.htm
Toyota Rear Springs up Front: http://www.pirate4x4.com/forum/showthread.php?t=265669
Chevy 63" Rear Swap: http://www.yotatech.com/showthread.php?t=71759
.......... http://www.pirate4x4.com/tech/chevyswap/index.html
.......... http://www.pirate4x4.com/forum/showthread.php?s=&threadid=20665
4Links: http://4wheeloffroad.com/techarticles/suspension/131_0306_link/
.......... http://www.4wheeloffroad.com/techarticles/suspension/131_0307_four_link_suspension_part_2/
Coil Conversions: http://www.yotatech.com/showthread.php?t=105460
.......... http://www.offroadsolutions.com/suspension.html#7995_coilover
Body Lift + Flat belly: http://www.4x4wire.com/toyota/tech/drivetrain_lift/
.......... http://www.4crawler.com/4x4/CheapTricks/DrivetrainLift/index.shtml
Steering:
.......... Rebuiding Stock: http://web.archive.org/web/20050322011020/http://128.83.80.200/taco/box.html
Winches/Winching: http://www.pirate4x4.com/tech/billavista/Recovery/index.html
Bumper Design
.......... Mulit-mount: http://www.yotatech.com/showthread.php?t=87892
« Last Edit: Mar 12, 2009, 11:09:58 PM by colsoncj »
87 4Runner, ProComp IFS lift, Chevy Rears, 4.88 w/ lockers Fr & Rr, plenty of goodies and creature comforts!
  • Momentum Man
  • Turtle Points: 759
  • Male Posts: 13,855
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: Links to FAQs and Information
« Reply #1 on: Jan 03, 2006, 12:30:28 PM »
And I thought I had too much free time, WOW!!!
colsoncj [OP]
  • Male Posts: 101
« Reply #2 on: Jan 03, 2006, 12:32:38 PM »
Ya... knowing where the stuff is at is wayyyy easier than searchin... so i just started a list, figured id share!
colsoncj [OP]
  • Male Posts: 101
« Reply #3 on: Jan 03, 2006, 01:01:50 PM »
Also lemme know if a link doesnt work in the future....
whiteman
  • Turtle Points: 669
  • Male Posts: 1,276
  • Member since Jan '05
    • Buy me a cigar
« Reply #4 on: Feb 16, 2006, 03:21:00 PM »
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
« Reply #5 on: Apr 13, 2006, 08:58:05 AM »
the very first one (pirate) says it is an invalid link.
I like to Drive!
colsoncj [OP]
  • Male Posts: 101
« Reply #6 on: Apr 13, 2006, 03:51:40 PM »
Thanks, I'll look into it.
colsoncj [OP]
  • Male Posts: 101
« Reply #7 on: Apr 13, 2006, 09:28:29 PM »
fixed.... and updated with some new links!!! :thumbs:
« Last Edit: Apr 13, 2006, 09:36:11 PM by colsoncj »
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
« Reply #8 on: Apr 14, 2006, 08:13:09 AM »
Thanks, this helps  :thumbs:
I like to Drive!
sgt.majorcrash
  • Turtle Points: -1
  • Male Posts: 59
  • Member since Sep '06
  • Pleasant Hill, Ca
« Reply #9 on: Oct 05, 2006, 05:20:59 PM »
Man thats all the information that I have searching for for the last few weeks. Man you kick a$$
colsoncj [OP]
  • Male Posts: 101
« Reply #10 on: Oct 08, 2006, 07:33:35 AM »
no problem.... as always, lemme know if anyone finds anything else, or if a link doesnt work!
MR_DIY
  • Turtle Points: -40
  • Male Posts: 595
  • Member since Sep '05
  • this is why I'm web wheelin'
« Reply #11 on: Oct 08, 2006, 08:09:43 AM »
thanks for doing this.  I don't really need any of the info but it's cool that it's here for general learning etc...  :thumbs:
I'm going yota JUST so I can buy from Marlin more.
*quote*-  goes to show that a ramp hero doesn't always have what it takes to be a trail hero as well.
colsoncj [OP]
  • Male Posts: 101
« Reply #12 on: Oct 08, 2006, 07:43:39 PM »
Hey, no problem!
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #13 on: Nov 28, 2006, 08:10:05 PM »
Marlin has provided the following information about lengths of the transmissions:
Marlin Crawler Transmission Dimension Chart
       by Marlin Czajkowski
TransmissionBellhousing  Shift Handle  T-Case Handle  Total
G52/G54 (84-87 22R Carb)6 3/8”19”23 ½”25 ½”
W56 A, B (85-89 22R EFI)6 3/8”21 ¼”025 ½”
W56 C, D, E (89-95 22R EFI)6 3/8”19 1/8”24 ¼”25 ½”
R150 (88-95 3.0 V6)6 ¼”21 7/8”024 7/8”
R151 (86-87 22R Turbo)6 3/8”19”23 ½”25 5/8”
W59 (96-04 22R, 3RZ Tacoma) 6 7/8”22 ¼”025 ½”
R150 (96-04 3.4 V6)7 3/8”23”026 1/8”
  • Administrator
  • Turtle Points: 2124
  • Male Posts: 18,291
  • Member since Apr '02
  • 511:1 Club
skyscraper
  • Male Posts: 589
  • Member since Jan '07
« Reply #15 on: Jan 21, 2007, 06:34:06 PM »
thanks man...this stuff really helps!
colsoncj [OP]
  • Male Posts: 101
« Reply #16 on: Jan 22, 2007, 04:19:57 AM »
no problem, thats what its here for!
Redeyejedi
  • Male Posts: 115
alcohol.....the cause of, and solution to, all life's problems
http://www.flickr.com/photos/78234902@N06/
Redeyejedi
  • Male Posts: 115
« Reply #18 on: Mar 31, 2007, 10:41:40 AM »
:wave:
more resources:
http://www.toyotaoffroad.com/Articles/Projects/Snorkleman_SAS/Snorkleman_SAS.htm  -  SAS
http://www.4x4wire.com/toyota/maintenance/front_end/solid_axle/   -  axle
http://www.4x4wire.com/toyota/maintenance/front_end/teardown/   -  axle
http://www.4crawler.com/4x4/CheapTricks/AxleRebuild.shtml            -  axle
http://www.4x4wire.com/toyota/tech/gear_setup/                          - gears
http://www.pirate4x4.com/forum/showthread.php?t=281879 - Rebuilding 1979-1985 Toyota Manual Locking Hubs
http://www.4x4wire.com/toyota/tech/arb_locker/   -  air lockers  8"
http://www.4x4wire.com/toyota/4Runner/tech/ifs_airlocker/  - air locker IFS
http://members.cox.net/drvic723/Steering%20box%20rebuild.htm   -  steeering box
http://web.archive.org/web/20050322011020/http://128.83.80.200/taco/box.html   steering box
http://www.pirate4x4.com/tech/billavista/Recovery/index.html  -  WINCHING - MUST READ!!!!!!  :hammer:
http://board.marlincrawler.com/index.php?topic=19684.0 - 3.4L swap
http://www.yotatech.com/showthread.php?t=82145 - 3.4L swap -  :bowdown: AMAZING. MUST READ. convinced i'm doin mine now..
http://www.urdusa.com/product_info.php?cPath=79_80&products_id=1230100017&osCsid=da265530a7d69c3890f13b50a24ab54b   -  3.4L SC Goodies :drooling:
 http://www.pirate4x4.com/forum/showthread.php?t=109103    - transfer cases
 http://home.off-road.com/~mithrandir/tcase/tcase.pdf           - transfer cases
http://video.google.com/videoplay?docid=-5417019303200331106&q=flying+man+rocket&hl=en  - not at all 4x related...but hella funny and crazee cool. i know what i want for christmas!!!!! :clap2:
« Last Edit: Apr 03, 2007, 02:11:46 PM by Redeyejedi »
colsoncj [OP]
  • Male Posts: 101
« Reply #19 on: Feb 21, 2008, 08:55:51 PM »
I would just like to say 1. I'm honored that my little list has now made it onto the mainstream of the marlin site, and 2. its updated!!!!
ninja turtle
  • Turtle Points: 38
  • Male Posts: 1,072
  • Member since Sep '07
« Reply #20 on: Feb 21, 2008, 09:24:47 PM »
thanks man.
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
  • Member since Dec '06
« Reply #21 on: Feb 22, 2008, 07:04:39 AM »
First link under steering does not work. Cool Thread! :thumbs:
colsoncj [OP]
  • Male Posts: 101
« Reply #22 on: Jul 13, 2008, 07:17:46 PM »
sorry for the slackin.. updated and fixed!
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #23 on: Jul 13, 2008, 07:20:31 PM »
Much thanks for fixing the steering one :bowdown:
colsoncj [OP]
  • Male Posts: 101
« Reply #24 on: Jul 13, 2008, 07:33:44 PM »
no problem... i've been slackin.. also added some new links for other stuff!!!!
NorCalToy
  • Official Super Badass
  • Turtle Points: 77
  • Male Posts: 2,472
  • Member since Jun '07
  • IFS no longer! - Member #8342
« Reply #25 on: Nov 07, 2008, 01:58:33 PM »
http://www.offroadsolutions.com/products/suspension.htm
2nd link under "coil conversions" doesnt work, but nice list dude, some good reading for a day at home sick
:flamer: IFS
  • Turtle Points: 2872
  • Male Posts: 8,707
« Reply #26 on: Nov 07, 2008, 02:08:43 PM »
thats because the host redesigned their website
this should work http://www.offroadsolutions.com/suspension.html#7995_coilover
colsoncj [OP]
  • Male Posts: 101
« Reply #27 on: Mar 12, 2009, 11:07:02 PM »
thanks jimbo... i'll get it updated!
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: Links to FAQs and Information 93 FSM for PU
« Reply #28 on: Oct 31, 2010, 06:39:06 PM »
Link for 1993 FSM - Pickup a lot of the same info applies to the 4-Runner.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Saved-wheeler
  • Male Posts: 53
  • Member since Jul '13
« Reply #29 on: Jul 04, 2013, 11:12:52 PM »
Great thread man, really helpful! Thanks for puttin it together!
Last post Sep 22, 2011, 06:52:20 AM
by jkimmel
Last post Oct 05, 2009, 08:01:58 PM
by NATER623
Last post Apr 24, 2011, 02:51:54 AM
by Rocksurfer
Last post Dec 02, 2011, 10:36:16 AM
by OOPS
Last post Jan 16, 2014, 12:25:06 AM
by Noz
