0 Members and 9 Guests are viewing this topic.
If you guys can get any of these contact names/ numbers for me it'd be great. So far I am being told that there can be no modifications until after the 2nd o2. Even though I'm putting out 1/5 of the emissions as the 22re did 2 yrs ago. This just makes no sense.
Hey Mike, I was going through this thread, and while on the first page were you have listed the different Toy engines and their output, I've noticed that the 4.0 and 4.7 dont have engine reference numbers, like the 22RE or 3RZ. I know that the 4.0 is a 1GR but what is the 4.7??
Sorry, I ment the 4.0 V6 1GR form the Tacoma and FJ's. I forgot about the Lexus V8.
Finally finished my project. I have a couple cosmetic things left and AC things but its smogged, registered and gets over 20MPG.Engine frontSMOG and fuse box in factory Tacoma positionsMAF and resonatorsSide view; E-Locker switches that still need to be mountedPassenger side view; Still trying to figure out the radio, no speakers, no sound. The Tacoma AC/heater and blower motor are under that dash.Drivers side view; Tilt wheel works, Speedometer is 2 MPH off with Marlin signal converter.The only 4-runner wiring left is for the rear window. The rest in all new from the 2000 Tacoma donor.Exhaust crossover; driveshaft clearance is an issue with the HP 3rdFront clearance; Electic fan was a must. There was 3" too little room for mechanical.Rear is tight. Just like I like it. Harness in factory position.85 4Runner2000 3RZ2000 Tacoma dash, wiring harness, AC/Heater systemFront Diamond Axle with 5.29 HP E-locker, Longfield 30's, Kongs Hi Steer,Rear Tacoma axle with 5.29 E-locker, Front Range Off Road Full Float Axle KitMarlin Dual case, Marlin 4.7 gears in rear case
Mine cracked almost all the way around, but who cares. I welded my back together and it stopped. Plus I've dynoed both and they have the same output to the wheels. If you get a good motor for a good price and it has the cast one on it, dont spend your money on buying another stock one. It's just throwing your money away. Buy an aftermarket header.
As for the amount of room the Taco dash takes up. Well, you got the pic's, what do you think.As for easy of install. Make sure that you use the Taco cross bar behind the dash, so you are not making new mounts for everything.
so today i tired to find out about the cooling problem, so i removed the thermostat and let it idle it got up to 220 so i killed it. So I checked the heater hose to see if the water pump was pumping good and it is. I think it maybe be a radiator and i need a shroud if someone has one.
Started by cruzila « 1 2 ... 32 33 » Rig Gallery
Started by yotaboy79 « 1 2 ... 32 33 » Chit Chat Camp
Started by BLACKDOG « 1 2 ... 11 12 » Chit Chat Camp
Started by Willy Mammoth « 1 2 3 4 5 » Chit Chat Camp
Started by Rocksurfer Chit Chat Camp
