Yeah, I was just trying to figure out of the EGR or modulator had anything to do with my fluctuating idle problem, or why it opens prematurely.. i havnt been able to figure that out.
i have a question......, since ytou guys are talking EGR and PCV.do they play a part in performance in engine on an 87 RE? or just for SMOG?will my engine run cleaner or better without either or without both?ive heard small rumors that it does....CLARIFY?
If you block off or render the EGR useless you not only might improve your drivability you also run the risk of having all the passages plug up from non-use . So when you go smog it again you'll have to remove everything to clean it out to make it operable in order to pass smog ($$$) . ''How much difference will it make?'', you ask. With the EGR inoperable it will show high NOX emissions and gauranteed ''fail''. With the age of your vehicle they will physically have to test it and they will find the modified component. So, "fix it or bypass it?", that's up to you. Either way, you could be in for a hassle only one will be right and be no further hassle and the other...not so much. Don't forget the EGR reduces NOX emissions by lowering combustion temps and can actually help an engine run cooler. I'm sure you see the benifit in that.
Whatever you do DO NOT modify your PCV system unless you're putting vented caps on your valve cover. If the crankcase is sealed you could have all kinds of problems ranging from minor to major oils leaks and even the possibility of explosion from the blowby gases trapped in the crankcase. Given the mechanical nature of the rings, no matter how good your compression is, the rings are never able to seal 100% especially in stock form.
I checked my EGR Valve it works good. The test's on the vacuum mod / BVSV have me a little concerned..The cold check @ 3500 rpm's the BVSV is ok "0" inches of vacuum. (GOOD)The Hot check is "0" inches of vacuum at 3500 rpm's, it should have low vacuum. (BAD)When I connected the modulator to direct vacuum the vacuum gauge should have high vacuum, I show "0". (BAD)The "cold" blow test of the BVSV, the air blows from port "J" to the top filter,, just not easy.. (?)The "hot" blow test of the BVSV, the air blows from port "J" to the top vacuum port "K" (GOOD)The vacuum modulator test with the motor hot, (I don't think this hot /cold here matters) Plugging the ports "P" & "R" blowing air into port "Q" the air won't pass thru easily (the FSM said it should blow "freely"to the filter side) (BAD)(I changed out the filter media to a foam pre-filter from a dirt bike) the original was pretty tore up. Is there any advise on what there is to do? The main issue is the damn intermittent miss at idle! And I've changed about everything!
I tested my EGR today by applying vacuum and the fsm says if it is working correctly the motor should stall. My motor just stumbled badly but would not stall. Does that mean the egr isent working correctly? Needs to be replaced or cleaned?
Started by BLACKDOG General 4WD Discussion
Started by 7m4runner Toyota Pickup/4Runner Tech 1979-95
Started by Skinny_Pedal General 4WD Discussion
Started by jimbo74 Toyota Pickup/4Runner Tech 1979-95
Started by CCXI New Member Check-In!
