Man I hate it when my bearings get hooped . I'm going to use that.Are the poly bushings an improvement? I used to do poly sway bar bushings on our Celicas and the difference was huge.
I'm wondering if I could fit some Bf Goodrich T/A K.O.'s in a 215/75-R15 with a bit of lift?
Butttttt those aren't 4wd tires........
Just finished modding my spare flasher to prevent Hyper flash with LED's. So now I can finally install the LED's that have been bouncing around in my glove box for several months. This mod might be useful to first gen pickup owners as well; I think they use the same flasher. open up the housing and unsolder the single 3.3Uf capacitor. Replace it with 2.7Uf and 4.7Uf capacitor in parallel. Be sure to keep the negative pole on the same side as the one removed.
Very nice! whats the paint code on that!
Toyota paint code 884. I get it in a spray can from http://www.automotivetouchup.com/Going with a FJ-80 hopefully one with an 1HD-t from Canada.
That cross member cracks me up
Everything on it is so small.
Fyi, this thing has a million parts. And the input shaft is only 14mm how does that even hold up!
Started by rlwjaw Project Research and Build-Ups
Started by crawlerdan General 4WD Discussion
Started by yotadork83 « 1 2 ... 6 7 » Project Research and Build-Ups
Started by weakyota91 Newbie Questions
Started by toe « 1 2 » Chit Chat Camp
