Author Topic: 30-Spline Chromoly Rear Output Shaft question  (Read 1874 times)
05sport4x4
  • Turtle Points: 3411
  • Member since Jan '07
« on: Jan 02, 2016, 10:42:48 PM »
I installed Marlin's 30-Spline Chromoly Rear Output Shaft and at the very end of the install I noticed the new output shaft is not bored for the speedometer detent ball.  The speedo will not work as the gear just spins on the shaft.  Has anyone else had this same problem?   I need to call them on Monday but to find out what is with this as for a street driven truck having the speedometer is a must and the item description does not say anything out it not working after the install.
Thanks.
John
05 4Runner Sport 4x4 V6 - Hanna Sliders
89 Extra Cab 4x4 Pickup, 3.4 w/auto conversion, Diamond 9.5" front, Ruffstuff rear 9.5", 5.29's w/ARB's, dual case 2.28-4.7, 40x13.5
05sport4x4 [OP]
Re: 30-Spline Chromoly Rear Output Shaft question
« Reply #1 on: Jan 07, 2016, 02:52:06 PM »
OK so I spoke with the sales office earlier this week and was told they do not make the hole for the detent ball in the shaft because the speedo gear has it's diameter enlarged to fit the larger shaft.  That does not leave much of the cutout for the ball left in the gear.  I'm told that just friction from torquing the output flange nut is enough to hold it tight.
John
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
« Reply #2 on: Jan 07, 2016, 07:51:12 PM »
So did that work for you? I'm interested in this for an upcoming build.
01 double cab hunting truck
06 tacoma street truck
05sport4x4 [OP]
« Reply #3 on: Jan 07, 2016, 08:56:40 PM »
I have to finish reassembly this weekend.  Then it goes back in the truck which is under the knife for a front 3 link and 63 chevy's in the rear.  I spoke with one of the sales people at Marlin's and said he has this setup and his speedo works fine so I assume it will work.  I just explained it might be good to specify that you don't use the ball on the page or to have specific instructions for this that explains you don't need the ball.
John
Goldrush
  • Turtle Points: 145
  • Male Posts: 1,381
  • Member since Jan '10
  • wheelin!!
« Reply #4 on: Jan 07, 2016, 11:03:56 PM »
Yes. Marlin Crawler has designed the 30 spline rear output not to have a detent ball because the bored out speedo gear has enough preload from the flange nut that it doesn't spin. I have built a couple and they work great. So much more heavy duty than a stock output!
Last post Jul 13, 2010, 02:08:26 PM
by boggerunner
Last post Nov 21, 2010, 11:12:10 PM
by twistedtoy92
Last post May 31, 2013, 02:21:44 PM
by BigMike
Last post Apr 13, 2012, 09:39:01 AM
by jrock
Last post May 11, 2023, 07:38:13 AM
by boredmuse
