Possible air flow/fuel problem
Started by Running_Gunning, December 02, 2015, 10:34:00 PM
Running_Gunning
Hello MC'S I am new to this forum and need a little insight for a problem I have. Thanks in advance for your help.
86 Toyota 4x4 Xtra Cab, idles perfect at startup,but upon throttle it bogs out and dies. I've replaced cap and rotor,plugs wires,fuel filter, fuel pump works but need to check pressure. Ran a self diagnostic check with  2 flashes  and then 8 flashes which point to the air flow meter or faulty ECU. I'm no expert, just trying to figure this out. Any suggestions or help would be very helpful. Thank you.
Sent from my SM-G900V using Tapatalk
redneckcustoms13
Check your tps first, make sure it is set properly and working as it should.
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
01 double cab hunting truck
06 tacoma street truck
Mason85
Mason85
Also could tops cause rich fault code?
