Having the exact same problem with my rig right now. I'm pretty sure that mine is due to the fact that I lifted my transmission and cases with my Sky's cross member and they are contacting the body now. However I notice that we are both running 84/85 front shafts re-worked for the rear. I wonder if there is something with that shaft that is causing this?
If I was closer to you I'd let you bolt in my rear driveshaft and see if it make any difference. Any chance your vibration is just getting amplifier to a level that feels concerning because of your heavy duty mounts?
Yeah... that's what I'm worried about. But, it's not crazy high, there must be other people out there with similar lift and dual cases.I just checked and the angle the shaft is running at is 16 degrees relative to the output flange of the tcase. Anyone know if that's too steep to run smooth? And would an issue like that smooth out after a certain speed, or just get worse and worse?Are there CV shafts out there that can run smooth at higher angles? I know there are high angle shafts but it seems to me that is just for preventing binding in super flexy rigs.This vibe feels/sounds a lot like a loose pinion flange I had back in the day, although that would only happen while floating the throttle. Flanges on this rig are tight so that isn't the issue. The last bad ujoint I had made a chatter/rattle sound, less deep than this.
I don't have a great way to measure this exactly right now other than a tape measure, so it isn't very exact. Difference in height between the flanges is just about 12". Flange-to-flange is roughly 39.5".I do have an angle finder here and can measure the operating angle to be 16 degrees +/- 0.5 degree.
Started by MiniSimp « 1 2 » Chit Chat Camp
Started by Bazzi Chit Chat Camp
Started by MiniSimp Chit Chat Camp
Started by 69800 Toyota Pickup/4Runner Tech 1979-95
Started by 86sasturbo Toyota Pickup/4Runner Tech 1979-95
