Duel case problems
Started by Madmanmirto, October 08, 2015, 07:00:52 PM
Madmanmirto
I replaced the rear case in my 85 pickup and now then in 2wd I shift the crawl box into low and will know the rear case into neutral and won't budge out unless I take shifter out and knock the linkage back forward didn't do this before with old case thanks in advance
blackdiamond
Did you pull the pin in the t-case and not install a twin stick?  Did you rebuild it yourself, order a rebuilt one from Marlin, or other source?
SqWADoosh
Quote from: blackdiamond on October 09, 2015, 06:03:13 AM
He came to the chat with this yesterday and it was figured out that he did not trim the rail like he was supposed to.
Cheesemaker
I was thinking that he forgot to cut the rail down.
blackdiamond
Quote from: SqWADoosh on October 09, 2015, 06:15:41 AM
Do you plan on pulling your pin?  I was surprised a bit that it was still in with the triple stick configuration.
SqWADoosh
Quote from: blackdiamond on October 09, 2015, 11:03:41 AM
When I go to 4.7 I'll do it. Hasn't been a bother.
