4wd light
Started by BLACKDOG, March 29, 2005, 12:59:13 PM
BLACKDOG
After I pulled the tranny, and put it back in, the 4wd light in my dash no longer works.  It isnt a big deal, but it is nice to have.  I know my truck goes into 4x4, so that isnt the problems, I think the plug was either plugged in wrong, or wasnt at all.  I have a 91 v-6 does anyone have experience with this?
              -Ronald Reagan
gnob
crawl under the truck and see if its plugged in.
hold this. . .
BLACKDOG
did that, I actually wasnt the person who unplugged them and plugged them back in so I am not sure which it is.  I am assuming it is the one in the t-case that is round, and actually screws on, not slides in.  Is that it or am I off?
              -Ronald Reagan
gnob
i dont know why you or whoever would have actually unscrewed the switch but yes, that is right.
as far as i know you cannot interchange the plugs.
go to the harness under there.
with key on you should have 12v at the harness, the switch in the case grounds and turns on the light.
hold this. . .
BLACKDOG
Are you not supposed to unscrew it?  We were dropping the tranny and t-case, and my buddy unhooked all the wiring.
              -Ronald Reagan
gnob
there is just really no reason to take it out if you are just pulling the trans and case, there is a connection.
you should just unplug it and leave the switch in the case.
if you unscrwed it with it plugged in you may have broken the wire or something.
hold this. . .
BLACKDOG
ok makes sense.  Guess thats what happens when I dont look before I tell someone to do it huh?
              -Ronald Reagan
gnob
you can check that switch, it should show continuity to ground in 4wd and open in 2wd.
hold this. . .
BLACKDOG
I'll have to wait til this weekend to check it, i dont have a voltmeter up here, gotta go get my dads
              -Ronald Reagan
stomper
Quote from: blackdog on March 29, 2005, 02:09:03 PM
I think your seeing the speed o meter cable. I think it should be a plug in connector.
BLACKDOG
thanks.  I'll check it out.  I havent even ooked under there since I asked the question, havent had a chance in the daylight
              -Ronald Reagan
