94 2wd sas
Started by ChadStich, July 26, 2015, 08:32:57 PM
ChadStich
The bump stop cans and shock clear with about an 1/8in at full drop out. its close but it will work.
94 2wd extra cab sas, 3rz, 4.30 e-lockers f/r, dual stock cases with marlin adapter, longs, 35s, RUF, Chevy 63's
http://board.marlincrawler.com/index.php?topic=99269.0
ChadStich
Got to test out the bump stops and new shocks. The shocks are great but I need to let a little nitrogen out of the bumps they are super stiff. Was still a good day of wheelin though managed to flop the truck on its side but somehow didn't put a dent or scratch in it.
ChadStich
Got some more done on the truck. Rebuilt some calipers and ordered rotors for the rear disk break swap and got that all done and a new proportioning valve. Pretty happy with the how much better they work. Also cut apart a rear housing to use for pressing out axles. worked great! Also got a psc power steering pump so I built a reservoir and got everything mounted.
ChadStich
The cap is my old re cap that I cut off and welded to this. All the fittings and hoses came from surplus center.
ChadStich
Final update for a while since I have to head back to school. Finally built a battery box so I could ditch the rafting strap.
Box layout.
little work with the plasma cutter and finger break.
Fits like a glove.
Ritchie
Looks good.
Did you get your PS reservoir dialed in yet?
'03 Step side Pre-runner, F/R 4WU 3 linked, F/R Diamond axles, F/R ARB's w/5.29's, F/R Fox 12" CO's, ShrockWorks front bumper, self made rear bumper, WARN M8000S w/ remote, 4.7 Inchworm Lefty, MC sliders that hold air & a bunch of other stuff.
ChadStich
Quote from: Ritchie on January 07, 2017, 04:44:57 AM
Looks good.
Thanks!
I filled it past the return and it quit cavatating but the fluid level is up so high that it spews out the cap. Im going to build another out of aluminum and TIG weld it all together and put the feed and return at the bottom.
ChadStich
Also got to take it out for one last go before it gets parked for a while. The snow was pretty much the exact opposite of ideal but it was still fun.
ChadStich
Got to go home over the weekend and tinker around a little bit. Finally put front blinkers on the truck and added some 3 in the morning hanging out in the garage with buddies racing stripes. not sure how much I like them but the whole truck is spray paint so its an easy fix. you can see one of the blinkers in the picture from the front. They were just some cheap LED lights from auto zone.
