Lockers
Started by flhtom, June 20, 2015, 09:01:42 AM
blackdiamond
Quote from: Mudder on May 24, 2016, 07:27:54 PM
Blackdiamond, how much does your 4runner weigh? I've been reading into the debate on selectable verses non-selectable.
I don't honestly know, but based on the curb weight I would guess under 3,500 lbs. I have larger tires, an extra t-case, bumpers, sliders, crossmember, winch with rope, and not much else.
Rockcrawlintoy
Quote from: Mudder on May 24, 2016, 03:31:28 PM
In regard to ARB's, I've heard that you have to run a good gear oil with them and zero water can get in the diff. If it does you need to change the oil ASAP and you should be good to go for a long time. An also to make sure your beather isn't plugged. Not saying problems can't arise, as with anything it can fail but that taking care of it is essential.
I ran cheap gear oil and changed it once after break in for 10 years. Only changed it after a seal finally failed after the truck sat for a year and a half. I will be running decent oil in my new ones here in a few months. We will see how it goes
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
:)bestgen4runner
Run that sweet pink stuff.
I am 1/5th of Perfect Fit
Snowtoy
Should never run cheap gear oil, but it isn't like you have to spring for royal purple or other synthetic diff oil.
If you run breather lines, something all trail rigs should have, you should never get any water into the diff
Not aware of the weight being part of the debate, what are the issues?
Willard
Quote from: SqWADoosh on May 24, 2016, 07:02:01 AM
It is fascinating to me the amount of people who are happy with their Truetracs. I wonder if it is people who have never experienced a real locker before?  :dunno: I hated my Truetrac and advise people against them all the time. For the money you could get so many better options.
I had a Detroit in my first truck with arb front and it worked great. Love having a full locker. But it also depends alot on how your suspension works. If your pulling tires off the ground all the time then yes the Tru Trac may not engage the way you want, but I hardly pull a tire off the ground and with duals I hardly even use my front locker. Thing does amazing, but I will say my Tru Trac has slipped up a few times. I just got my hands on a 14 bolt and will be installing an arb for sure in the rear, but I will recommend a Tru Trac to people depending on application and use  :thumbs:
Mudder
Quote from: Snowtoy on May 24, 2016, 09:54:50 PM
Oh it just seemed like when people mentioned that they run auto lockers the ones with a heavier rig didn'tond them as much in bad weather. At least that's what I gathered
blackdiamond
Quote from: Mudder on May 25, 2016, 06:17:23 AM
I think the key to a street driven automatic lockers is being smooth. There is definitely more play between the drive and coast side of things and it's a more forceful transition. More weight and an automatic transmission both have potential to soften the transitions.  If you can't drive smoothly then an automatic locker may not be a good choice.
Rockcrawlintoy
It was just the sta-lube gear oil. Ran it for years with no issues
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Snowtoy
Quote from: RockcrawlinJK on May 25, 2016, 09:18:44 AM
Didn't think sta-lube was considered cheap, :dunno:  I think the last stuff I used was valvoline.
H8PVMNT
Sta-Lube containers look rather generic but I think it's pretty good stuff.  Not real cheap.  My old timer parts guy swears by it.  I got the GL-4 for my trans and t-case this year. I was going to get redline but my guy couldn't order it.  Trans shifts nicer and is quitter than the GL-5 I had in there, so the Sta-Lube must be better than average anyway.
– Steve McQueen
blackdiamond
Quote from: H8PVMNT on May 26, 2016, 01:10:55 PM
I would guess the GL-4 stuff should perform great in the transmission.
