Gentlemen,
Its time to get my old pickup up and running again!! I am in need of some help locating the homes of particular wires to re install my 80 AMP ALT fuse. It blew a while ago and was removed then. Pictures were taken for the re install but a case of butter fingers ended that phones life, thus losing my pictures. With the lesson learned, I'm asking for pictures of this fuse installed so i may see what wires go on which side of the fuse. i understand this may be a large request being the engine fuse box must be unbolted, then after removing the bottom cover, slide the 80 AMP ALT fuse secondary block out of the bottom exposing the wires bolted to the fuse itself. If so inclined to assist, Disconnect the battery before beginning. I appreciate any help i can get!
