I'm going to be putting OME springs on my '84 truck with 5" shackles front & rear.
Rancho sells the RS9000 in a couple of different versions including one for 1" lift (
![Huh??? ???](https://board.marlincrawler.com/Smileys/marlin/huh.gif)
) and one for 3" lift. I'm guessing I'll be closer to 3" with this setup and that's probably the one I should get but thought I'd check in with the gurus around here first. The 3" shock specifies the bump stop should be lowered 2" to prevent shock damage.
Or, should I just get Bilsteins? I can't find a part number for Bilsteins for lifted rigs. Will the stock application Bilsteins work or does anyone know of a Bilstein application that would be better for my setup?
Thanks!
