Author Topic: what's leaking?  (Read 1593 times)
zach0786
  • Member since Feb '15
what's leaking?
« on: Mar 03, 2015, 10:21:32 AM »
I have a small leak between bell housing and engine. Sure its motor oil.  Had to add little bit yesterday. All other fluids are good. What could be leaking.  Help would be greatly appreciated. Btw its an 89 Toyota 4runner 22re 5speed i believe it's w56-c
Nation
  • Turtle Points: 1141
  • Male Posts: 1,565
  • Member since Mar '13
  • @nationallmotors
    • Buy me a soda
Re: what's leaking?
« Reply #1 on: Mar 03, 2015, 10:25:34 AM »
It could be the half moon gasket on the back of the valve cover... or your rear main seal.. find the highest point of oil .. if the oil is on the outside of the bellhousing and making its way down I'd say half moon.. if it's only visible from the bottom of the bellhousing/motor I'd say rear min seal...
mudmaster
  • Turtle Points: 3715
  • Male Posts: 2,854
  • Member since Feb '05
Re: what's leaking?
« Reply #2 on: Mar 03, 2015, 01:42:56 PM »
^^^What Nation said^^^
Time to go wheelin!
81 shortbed
  • Turtle Points: -5
  • Male Posts: 329
  • Member since Nov '13
Re: what's leaking?
« Reply #3 on: Mar 03, 2015, 02:59:56 PM »
^^^what mudmaster said that nation said^^^
1985CRAWLER
  • Turtle Points: 267
  • Male Posts: 1,163
  • Member since Feb '13
  • Backyard Built
Re: what's leaking?
« Reply #4 on: Mar 03, 2015, 03:23:19 PM »
engine oil=half moon or rear main, possibly valve cover gasket.
Gear oil=tranny input seal or seal housing gasket.
zach0786 [OP]
Re: what's leaking?
« Reply #5 on: Mar 03, 2015, 04:44:46 PM »
Gonna  try and track it down again  tonight.. i cleaned every thing  off real good so i can see leak better. Hope its something simple to fix. Thanks  for y'alls thoughts
ThorInc
  • Turtle Points: 68
  • Male Posts: 18
  • Member since Oct '14
Re: what's leaking?
« Reply #6 on: Mar 08, 2015, 12:28:31 PM »
Rear main will drip through hole at bottom of bellhousing.  Depending on the size of the leak, you maybe able to see it drip through that hole while idling.
Sent from my SM-N900W8 using Tapatalk
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: what's leaking?
« Reply #7 on: Mar 08, 2015, 05:20:16 PM »
Half moon
Half moon
Half moon
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
helipilot77
  • Turtle Points: 1018
  • Male Posts: 1,729
  • Member since Jul '12
  • Seattle, WA
    • My build thread
Re: what's leaking?
« Reply #8 on: Mar 08, 2015, 09:26:52 PM »
If it's not any of the ones listed above, there may be a possibility that it could be the head gasket. My diesel is exibiting the same symptoms right now and it is being caused by the head gasket. Don't even think about diving into it that far until you have eliminated the other possibilities listed above though.
Last post Oct 31, 2004, 06:48:01 PM
by BigMike
Last post Sep 02, 2005, 01:33:58 PM
by germ
im leaking.
Last post Apr 27, 2006, 10:35:10 AM
by Wermz84
Last post Sep 17, 2007, 09:13:01 PM
by DeMented Toys
Last post Mar 04, 2015, 04:43:39 PM
by MRHilux87
