Aug 04, 2024, 12:07:27 PM
Welcome Guest, Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Store
Calendar
Members
View the memberlist
Search For Members
Login
Register
All
Current Board
Current Topic
Our classic Hot August Sale is back!
Save 10% site-wide!
Click for details
Technical Discussion
Suspension
(Moderators:
Brandon
OOPS
lilbuddy
Cheesemaker
Topic:
Spring ID and other questions
Pages: [
1
Go Down
Print
Author
Topic: Spring ID and other questions (Read 2546 times)
Sharpie330
Rock Crawl'n
Turtle Points: 1
Member since May '13
HE>i
on:
Dec 27, 2014, 07:28:43 AM »
Hey guys, I have recently obtained a complete front and rear set of solid axles, MC 4" springs, high steer, gears lockers and other stuff. It all came off a 91' pickup, front axle from a 84'.
Question is this, previous owner wasn't sure what the actual height of the lift kit was that he bought from MC however many years ago. The springs have TOY33 FRONT and TOY33 REAR printed on them. Is that enough to know what kit it was?
I have already done the rear leaf conversion and installed my V6 third in the housing, the rear seems to sit quite a bit lower than the front does, front is still IFS mind you. If the front sits considerably higher than the rear after I do the axle swap is it acceptable to just swap out the rear shackles for taller ones?
Thanks!
3:30 HE>i
Logged
John 3:30 He must become greater, I must become less.
84Flatbed
Crawler Guru
Turtle Points: -196
Member since Jun '13
Crawling with Marlin
Re: Spring ID and other questions
Reply #1
on:
Dec 27, 2014, 09:12:58 AM »
Yep, those are 4" springs. How long of a shackle are you using in the rear now? A longer shackle should be ok but for every inch longer you only get a 1/2" lift. I think some people also run a taller spring in the rear on the 4Runner, like 4" front with 5" rear.
Logged
Sharpie330
[OP]
Rock Crawl'n
Turtle Points: 1
HE>i
Reply #2
on:
Dec 27, 2014, 09:21:25 AM »
My shackles are sitting at 40 degrees loaded. Will longer shackles change that? How long is too long?
I tend to think about things too much. I haven't even done the front yet so I don't even know if I will need to make an adjustment.
Thanks!
3:30 HE>i
Logged
84Flatbed
Crawler Guru
Turtle Points: -196
Reply #3
on:
Dec 27, 2014, 10:42:54 AM »
It's my understanding that a longer shackle reduces the angle, but I can't imagine an inch or two changing the shackle angle much. I have 6.5" (hole to hole) shackles on my pickup and personally wouldn't want much longer than that. Another side effect of longer shackles would be a pinion angle change. What length shackles do you have on the rear now? Blocks are another option. As much as I see people saying to stay away from blocks I sure do see a lot of rigs with them, especially people running chevy springs.
Logged
Sharpie330
[OP]
Rock Crawl'n
Turtle Points: 1
HE>i
Reply #4
on:
Dec 27, 2014, 05:59:20 PM »
They are 6" eye to eye that are on the truck right now. Could I make some that are longer? Or would blocks be in order if need be?
3:30 HE>i
Logged
H8PVMNT
Silver Turtle Award
Turtle Points: 452
Member since May '07
I'LL NEVER MAKE IT...
Reply #5
on:
Dec 29, 2014, 08:25:22 AM »
You can throw a few more leaves in there too. I have like 8 leaves on my chevy rears on my 4runner and it still rides nice and flexes like mad. Actually I think I have 9 leaves on my passenger side.
Logged
– Steve McQueen
"Except for maybe Seattle." -H8PVMNT
"I plan to hit 300k in this truck" :)bestgen4runner
"I'm jealous of your shop. It has concrete and doesn't smell like pickles like the old shop " 300K
84Flatbed
Crawler Guru
Turtle Points: -196
Reply #6
on:
Dec 29, 2014, 09:38:11 AM »
You probably could add some kind of add a leaf, I wouldn't go with too short of a leaf though.
Logged
Sharpie330
[OP]
Rock Crawl'n
Turtle Points: 1
HE>i
Reply #7
on:
Jan 01, 2015, 07:23:45 PM »
Thanks guys I will look into that!
3:30 HE>i
Logged
Sharpie330
[OP]
Rock Crawl'n
Turtle Points: 1
HE>i
Reply #8
on:
Jan 03, 2015, 06:00:23 AM »
Here is how it sits now with the front and rear done.
Will adding a leaf in the rear make the ride stiffer?
Suggestions?
Thanks!
3:30 HE>i
Logged
84Flatbed
Crawler Guru
Turtle Points: -196
Reply #9
on:
Jan 03, 2015, 09:39:00 AM »
Ussualy adding a leaf will make it stiffer, but it will hold more weight. The shorter the leaf the stiffer it will be, that's why I would add a leaf similar in length to your middle ones. Might have to do a small block and a leaf. I'm not sure but if you start adding to many leafs to a lift spring you might sacrifice ride and flex.
Logged
H8PVMNT
Silver Turtle Award
Turtle Points: 452
Reply #10
on:
Jan 04, 2015, 12:18:19 PM »
I have like 9 leaves in my chevy 63" rears and it still rides smooth. It's mostly longer leaves not a ton of short thick overloads though.
Logged
– Steve McQueen
Dirt Mover
Rock Master
Turtle Points: 186
Member since Sep '03
Chrome won't get you home
Reply #11
on:
Jan 04, 2015, 08:42:39 PM »
If you are running the factory e brake you'll be limited to how many leafs you can add before the cable won't fit over the springs. Adding more leafs works great, but it can be a guessing game
Logged
Pages: [
1
Go Up
Print
Suspension
(Moderators:
Brandon
OOPS
lilbuddy
Cheesemaker
Topic:
