grease the out of it, and run it
i would still keep the cv front driveline, it will keep vibes down, unless u go to a square one then i wouldn't worry about it.u will also have to swap out or drill out the front output flange if u go to the basic u joint end since the bolt pattern is different, unless u have a triple drilled flange.
With a single case the cv is a must but with dual cases Ive found a non cv front shaft is best. This is based off running ruf/63'' suspension. From what Ive seen the angles are always alot closer to non cv angles. Ive run a cv before and got vibes at speed, 35mph +. Im currently running a highangle non cv front shaft. I have to grease the crap out of it ALL the time or I get vibes at speed, otherwise its smooth. I will go with someone that uses a tighter spline next time. That shaft looks like it needs grease bad!
you sure that isn't a flush style zerk fitting that takes a needle grease gun?you could always take note of how it is phased, make a mark with a marker or whatever, and pull the slip out and put grease in by hand.. and reassemble it the same way it came apart
Started by 81RockerToy Parts For Sale
Started by bluetoy84 Engine
Started by RunnerRick Engine
Started by 82TRD Parts Wanted
Started by B-R-I-A-N Engine
