Jul 16, 2024, 06:46:01 PM
Welcome Guest, Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Store
Calendar
Members
View the memberlist
Search For Members
Login
Register
All
Current Board
Current Topic
Around and About
New Member Check-In!
(Moderators:
*FFC*
Cheesemaker
Topic:
Hello from Downunder!!
Pages: [
1
Go Down
Print
Author
Topic: Hello from Downunder!! (Read 2654 times)
androxy
Dusty Trails
Turtle Points: -32
Member since Dec '14
Crawling with Marlin
on:
Dec 10, 2014, 06:21:31 AM »
Hi everyone,
Another newbie thread lol.
Anyway, I'm from Brisbane, Australia and am in the middle of building a RN130 Surf. Here's a pic if i am allowed to post
This was taken after the initial SAS was completed. I am currently in the middle of a 3RZ swap from a 22r ( Charging system issues if anyone can help) However at the same time it turned into moving front diff further forward, installing dual transfer cases, dual fuel tanks, front and rear winches, front and rear detroit's, custom bar work, longer shocks and towers, rear disc brake conversion and the list goes on and on as I'm sure most of you are used too.
I should also take this opportunity to thank all contributors to this forum as it has been a massive help so far in my journey.
Cheers
Logged
toyodaaddict
The 1K Club
Turtle Points: 399
Member since Sep '08
Re: Hello from Downunder!!
Reply #1
on:
Dec 10, 2014, 12:08:23 PM »
Logged
MRHilux87
Crawler Guru
Turtle Points: -306
Member since Apr '11
Reply #2
on:
Dec 10, 2014, 01:57:22 PM »
Welcome. Looks awsome. I just finished a 3rz swap myself. Good little motor. How does the rear suspension work? Ive only had one 3rd gen four runner and it was swapped with leaf springs.
Logged
1987 4Runner. 3RZ. SAS Duals 5.29 Elocker Rear Detroit front 35s... Hydro assist
2007 Cummins 6.7 DRW g56. deleted EFI live.
2013 Ninja 1000
SOLD:
2006 Mitsibishi EVO 9. 347WHP runs 12.2s - Wifes daily driver. Ducati 916 - track bike.
81 shortbed
Rock Master
Turtle Points: -5
Member since Nov '13
Reply #3
on:
Dec 10, 2014, 02:08:21 PM »
Welcome. Nice truck
Logged
1985CRAWLER
The 1K Club
Turtle Points: 267
Member since Feb '13
Backyard Built
Reply #4
on:
Dec 10, 2014, 09:41:47 PM »
is that a 3rd gen double cab in the background?
Logged
toe
The 1.5K Club
Turtle Points: -60
Member since Dec '09
Reply #5
on:
Dec 10, 2014, 10:34:55 PM »
Logged
Me
androxy
[OP]
Dusty Trails
Turtle Points: -32
Reply #6
on:
Dec 11, 2014, 04:51:21 AM »
Thanks for the welcome.
The rear suspension is a 5 link rear, its had a little modification as i had to move a few things around to fit the disc brakes etc..
The grey truck is my housemates, it was the project prior to starting mine. We call it a LN106 Hilux over here, 1993 model, it has the 2.8L Diesel from factory, just about to get a hair dryer. Its running a 3' lift, rears up front, hoops, extended shocks, invert rear shocks, cromo front axles, reduction gears, spartan front locker, yukon grizzly rear and some other bits and bobs.
Logged
1985CRAWLER
The 1K Club
Turtle Points: 267
Backyard Built
Reply #7
on:
Dec 11, 2014, 08:16:19 AM »
its diesel too? oh god
tell him to make a build thread please!
do u have the stock links in the rear? or did u lengthen them? i hear off road that stock setup links with a lift can be really unpredictable and can tip u over really quick.
Logged
androxy
[OP]
Dusty Trails
Turtle Points: -32
Reply #8
on:
Dec 11, 2014, 11:15:16 AM »
It's actually my first time dealing with a coil suspension setup off road. I have extended the panhard and fitted a drop bracket to compensate for the lift but at the moment the arms are all factory. I am going to do some testing with them first and see how it all works out on the trail.
There are some guys running around on extended land cruiser arms over here but I'm not sure if they increase stability at all. Unfortunately there is not a lot of info about these rear coil suspension setups, may be a little trial and error. And if all else fails chop it out and go back to basics.
Cheers
Logged
Momentum Man
Gold Turtle Award
Turtle Points: 730
Member since Jul '04
Lego Enforcement
Reply #9
on:
Dec 17, 2014, 09:16:53 PM »
II
Logged
androxy
[OP]
Dusty Trails
Turtle Points: -32
Reply #10
on:
Dec 18, 2014, 02:44:38 AM »
Thanks for all the welcome's.
Logged
Pages: [
1
Go Up
Print
Around and About
(Moderators:
*FFC*
Cheesemaker
Topic:
Subject / Started by
Replies
Last post
newby from under downunder
Started by
stufftheifs-
Feb 13, 2012, 08:51:45 PM
by
luvyota
