Wheelbase questions...
Started by RCKSQRL, March 23, 2005, 07:03:09 AM
RCKSQRL
Ok all-
at the point where I am figuring the best wheelbase to run. '82 which was 102", has been stretched to about 106" at this point, I have the option to take it out another inch with my spring mounting point. What is the sweet spot to run? I know that when I had gone out with the heeps, I had a much easier time with the majority of the trails with my wheelbase then they did. Years ago I seem to remember that the "rockcrawlers" were being put around 110", can't seem to find too much info now. Seems they are going back down again.
I am not planning on competing in anything, this will be a driver that is set up for most if not all trails. Looking to see what wheelbase you are all shooting for or have found has worked best for you. I love rockcrawling and am not afraid or damage, toy axles planning on 38's with my 4.3.
thanks in advance,
'85 EFI Runner
4.3 with 700R4- for sale
5.29 detroit F/R
Front 3 Link with air shocks
rear 4 Link
Custom Fuel cell
8274
Crawler #719, rear with 4.70 # 677,
Twin stick
Skys manufacturing T-case crossmember
6 point cage modified with harness bar, dash bar and PRP seats mounted to cage
2 feet chopped off the back
It seems it is never done........
in works for new body and exo, motor and trans swap...
burnyota
not sure what everyone else runs, but I about 103.5
85 p/u, marlin#208, built 22R on propane, old school longs, 5.29's / detroits, bobbed, chopped, and flopped
MiniSimp
Truggy
It depends on what you run with your toy axles 106 will work well for you with turning and on inclins and decents.  although with a 38 inch tire you want that extra inch to help clear the tire. it wont hurt performance
Building the CRUISER
brainlessfool
I think my 83's at 128" or there abouts. (don't do the con with my truck!)
Mine is at 127" as it sits now.  I can adjust in to 130" if I ever make it to disney OK. :hahaha:
brainlessfool
Quote from: WHITE_TRASH on March 23, 2005, 01:12:51 PM
sounds mickey mouse to me.  :hammer:
blackdiamond
My 85 extended cab long bed is about 111", stock should be 112.5" I think.  I think my lift pulled the rear axle forward a bit.  My wheel base works great in Moab, but is a bit long for some of the tight sections in Washington State...too many trees!  I made it down Blackbear Pass in Colorado without any turning problems.  In Moab Dump Bump seems to be easier for long wheel base rigs and I have seem many pictures of standard cab Toys going up with ease so I should think that 106" range would be great!  I would doubt if you can really tell a difference on the trails with a 1 inch difference.  Shorter is better in some places and longer is better in others.  I think that 106" is long enough and would suggest keeping it that length to slightly improve maneuverability.
MiniSimp
*From the factory manuals:
1979-83 short bed 101.77 *
1979-83 long bed 110.24 *
1984-89 4Runner 102.95 *
1984-88 xtra cab 112.20 *
1984-88 single cab short bed 102.95 *
1984-88 single cab long bed 112.20 *
1984-88 double cab real short bed 112.20 *
1990-95 4Runner 103
1989-95 short bed 103
1989-95 long bed 122.5
1989-95 xtra cab 122.5
1995.5-?? Tacoma ??
1996-?? 4Runner (taco based) ??
mine is at 115" right now.  I think right around 106-108 is pretty good.  I have had a few problems with my longer wheelbase were a friends toyota (106") goes right through the spot were i had trouble.  this was on the rubicon.  Although, once i get the 4.7 and front locker it won't be a problem.
rockhound
Around 114". A little more stable on climbs and drops, but three pointers are mandatory for tight turns.
How you 'sposed to know what your limitations are, till you exceed them.
www.RunandPlayMotorsports.com
fourwd1
My Runner has been stretched to 106", and it works great.
'80's Toyota 4WD P/U, Buick 231 V6, Holley 4 bbl, Weiand intake, Downey headers, custom TH-350 L/U w/700R4 low gearing, dual tanks, dual batterys, other crap ...
- - - as seen in FOUR WHEELER magazine July 2006 - -
84 4Runner ARBed 5.29's F&R, 4.7 t-case, x-over, Chevy's, 2" drv train lift, 36" TSLs, 30 spline Longs, BudBuilt skid
backseatwheeler
i would suggest right around 105-110 anywhere in there would be pretty good especialy with some 37s
