Need to replace 5speed in 84 long bed 4x4.
Started by 12 valveR, August 31, 2014, 01:35:37 PM
12 valveR
I need to replace the 5speed in my 84 pickup. My question is can I swap a different type of trans in without any problems I have a w56 laying around with the transfer case?
Nation
Are you done yet?  W56 is the one to have.
12 valveR
I guess my question is will my drive shafts bolt up or is it a simple swap?
1985CRAWLER
simple swap and your drivelines should bolt right up.
is the w56 u have a top shift or forward shift?
Nation
Yes. Shouldn't have any issues. You'll need a different Trans tunnel cover thought. The location of the sticks are different.
Nation
1985CRAWLER
Quote from: NATION on August 31, 2014, 09:57:26 PM
Aren't  All W56 Top shift?
just w56A's and w56B's 85-87 or 88 i think.
i have a w56e in my 94' and its a forward shift
they are super stout trannys
12 valveR
Thanks for the help I will start on this tomorrow/today. My 84 is forward shift my other is top.
