Author Topic: Alignment  (Read 1474 times)
sect8dr
  • Member since Aug '14
Alignment
« on: Aug 13, 2014, 09:46:54 AM »
I just picked up an 85 4runner with some kind of suspension lift and a body lift.  It has Crossover high steer and It pulls to the left very badly.  Just wondering if anyone has any tips on aligning these high steer kits.  Thanks for any help.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: Alignment
« Reply #1 on: Aug 13, 2014, 03:47:16 PM »
I made some alignment bars the bolt on to the lug studs. I have them marked in the center and on each end for my tire size. With them bolted on I take a measurement on the front and back marks, looking for a 1/8-1/4 inch difference, smaller in front for "toe-in". I have used this method all of my life on go-carts to top fuel dragsters and all solid axles in between. Toe-in is the only easily made adjustment on Toyotas!!
1985CRAWLER
  • Turtle Points: 267
  • Male Posts: 1,163
  • Member since Feb '13
  • Backyard Built
Re: Alignment
« Reply #2 on: Aug 13, 2014, 03:58:04 PM »
excellent example provided by oops, dont take it to a shop, they will charge u a buttload and u will just be back again after a few wheeling trips.
i do mine this way and it works all the time. tire wear is even too.
u can also use a piece of flat bar clamped to the rotors. i used some flat wood once as well
sect8dr [OP]
Re: Alignment
« Reply #3 on: Aug 13, 2014, 07:50:08 PM »
Yep, toe in is about 1/4" by my measurement.  I am starting to think the leak at my IFS gear box could have something to do with it.
1985CRAWLER
  • Male Posts: 1,163
  • Backyard Built
Re: Alignment
« Reply #4 on: Aug 13, 2014, 07:57:41 PM »
make sure the nut on top of the box is tight
jssgbsn
  • Turtle Points: 440
  • Member since Sep '13
Re: Alignment
« Reply #5 on: Aug 14, 2014, 01:32:56 PM »
a bent axle housing could cause it or a ruined wheel bearing or steering knuckle misalignment
I read somewhere that after you drive around for a bit if you put your hand on the locking hub and its hot, it could be a bad wheel bearing, which would drag more and cause a dive to that side under breaking and could cause drift also
If I don't ask the stupid question, who will?
85 Runner, 22RE, AEM 'warm intake', TRD Cam, LC Headers, Dual Case, 5.29's, ARB Front Locker, Detroit Rear Locker, 35's, V6 Brakes, ARP Studs, Marlin Arms/Caps/Hy-Steer, Winch, Armor, Can-Back Top....and...
...more Gremlins than Gizmo the Mogwai was responsible for.
Last post Nov 14, 2004, 02:31:12 PM
by Duffil
Last post Jun 27, 2005, 04:44:16 PM
by WHITE_TRASH
Last post Mar 08, 2007, 07:52:50 PM
by 79coyotefrg
Last post Jul 10, 2013, 03:07:37 PM
by Cheesemaker
Last post Mar 12, 2018, 07:45:38 AM
by fasterspider
