75-95 Toyota Pickup Truck 4Runner Part Liquidation Venue OEM ETC I ship from CT
Started by Erick561, June 14, 2014, 08:55:34 AM
0 Members and 6 Guests are viewing this topic.
What Generation Do you need parts for?
1979-1983 1st Gen Toyota Hilux, Trailblazer, Wolverine
34 (40.5%)
1984-1988 2nd Gen Toyota Pickup Truck
18 (21.4%)
1984-1989 1st Gen Toyota 4Runner SUV
22 (26.2%)
1989-1995 3rd Gen Toyota Pickup Truck
6 (7.1%)
1990-1995 2nd Gen Toyota 4Runner SUV
4 (4.8%)
Total Members Voted: 84
HogCanyonHopper
Hello- I need a 22RE throttle cable to use for my 3rz swap into an 81 pick-up. Let me know what ya got. Thanks. - Joe
Erick561
88 3vz Gas Tank Sold
2 22RE AC Compressor Brackets Sold, 1 left
84-88 G series forward stick shift lever sold
22R Manual Bellhousing Sold
84 Sway Bar Sold
88 Sway Bar Sold
22R Distributor Sold 1 left
79-85 Rear Leaf Springs Sold
Gas Tank Skid Plate Sold
22R Starter Relay Sold
89-95 xcab rear driveshafts sold
1992 rear axle complete $250 cash local pickup
92 22re gas tank for sale
89-95 rear leaf springs sale in queue
Parting out 1992 3rd gen xcab pickup lmk what you need
Pending sale on 1989 non sr5 mechanical speedo odometer cluster,
1992 sr5 4 cylinder digital speedo odometer cluster for sale
89 speedo sold + 92 gray dash pad sold www.hardlinecrawlers.com
i still have the main dash sub assembly for sale
22R high pressure line, power steering pump, fluid cooling hardline with hose, 2 ps pump brackets and TOYODA reservoir with hose sold, 1 left 1992 22re
1992 power steering box for sale 89-95
22r backing plate sold, 2 left
84-88 cab sold, 1 left
92 power steering setup sold, still have the PS box available
79-85 front leaf springs for sale
Crossover steering for sale
4.37 front diff for sale
Ifs skid plate for sale
Lspv for sale 84-95 3 line + bleeder without the actuating arm
2 22RE heads for sale
79-83 2-line hilux lspv sold
84-88 doors sold 1 pair left
84-88 sunroof sold
Let me know what you need, i just made some space in my inbox.
Erick561
2 22R fan blades sold 2 left
84-88 hood latch center support sold 2 left
84-88 center dash radio support sub assembly sold 2 left
84-88 heater control face plate sold
89-95 sun visors sold 1 pair left
84-88 v6 89 4Runner plastic heater control valve sold
1992 front driveshaft sold
Transfercase crossmember shield sold, 2 left
Crossover Steering sold $300
Egr crossover plate on back of head sold 2 left
22RE water pump pulley sold
22RE cast iron exhaust manifold with egr tube sold
Pending sale on 1992 xcab frame
2 4.10:1 7.5" differentials for sale
4.37:1 front 8" differential for sale
1992 xcab frame sold, cab still available for sale
1991 front diff
1992 front diff
Solid front axle parting out. Tube is straight
92 ifs power steering box
avenger
Hello, I am dying to find this air hose
for sale by chance?
Erick561
81-90 22R EGR Valve sold, 3 left
84-88 blue main dash sub assembly sold, 1 blue one grey left.
Pair of 84-88 red hood hinges sold, 1 blue one red pair left for sale
84-88 hood latch center core support sold, 1 left
84-88 non ac heater blower motor with box assembly sold, 2 left
84-88 Chrome SR5 Windshield Trim from the 1988 v6 truck i parted out, SOLD
79-95 4x4 Oil Pan sold, 1 left
2wd oil pan and oil pickup tube available
84-88 22R Carb Distributor sold, 1 left
79-83 SFA 4x4 skid plate sold
84-88 non ac heater core and box assembly sold, 1 left
2 IFS 86-95 4wd skid plates sold
3 pair of 22R transmission stiffener brackets sold, 2 pair left
22R valve cover sold, 1 left
4wd oil pickup tube sold, 1 left
89-95 Manual Clutch Pedal Assembly Sold
1984 22R Cylinder Head sold www.toyotaminis.com
Pending sale 1985 front solid axle housing
Pending sale 1985 Aisin Manual Locking Hubs
Pending Sale 8" third member
2 ifs 7.5" front complete diffs still available
Erick561
Ifs diff sold one left
Solid front axle tube sold, parting out solid front axle
22r intake manifold sold
V6 tranny stiffeners sold
V6 stick shift sold
22re throttle cable sold
22r stiffeners sold 1 or 2 pair left
Pending sale igniter and motor mounts
Pending sale 22r air cleaner tube with emission box
Erick561
Quote from: avenger on May 08, 2016, 01:46:15 AM
Hello, I am dying to find this air hose for sale by chance?
I can usually locate a part in less than 1 day on a weekend or in a matter of minutes during the week depending if I am working or not.  I found this for you in a couple mins, i sent you the link.
22R plastic fan shroud, fan blade and fan clutch sold
85 solid axle knuckles sold to my returning customer
22R backing plate sold 2 left
89-95 forward shift tranny and tcase stick shift levers with the baseplate sold, 1 pair of shifters left
22R motor mounts sold 6 pairs left
22re alternator bracket sold 5 left
22R igniter coil sold
22re ac compressor bracket sold
92-95 digital 22re sr5 speedometer cluster sold
22R throttle cable bracket sold
89-95 toyota pickup windshield wiper motor sold
75-84 early 20r 22r timing chain cover sold
79-95 y bracket power steering brace sold
79-83 manual clutch pedal brake pedal assembly combo sold
2 pair 22r transmission stiffeners sold i believe i am all sold out of them for now.
Complete upper power steering bracket system sold 1987
Gray 89-95 lower steering wheel dash bezel panel with hood release lever sold, 1 gray left
84-88 door hinges sold 1 pair left
Gray 89-95 kick panels sold 1 pair left for cheap
22r starter relay sold
Help me downsize i have made a lot of progress and i am building my customer base.  Buy with confidence
Erick561
3vz engine sold, 1 left parting it out good heads good block good crank 4wd
92-95 22re coil igniter sold, 2 92-95 22re distributors still available for sale along with about five hundred parts dying for the trails and to help you get to and from work, etc.  Let me know if you need any parts cuz i can't use them all right now i can only do so much
Erick561
Pending sale 87 cab shell
Erick561
Pending sale right lower control arm and power steering harmonic pulley
Erick561
Helping a friend part out his farm truck, selling the front clip today everything else is for sale first come first serve
Erick561
Lower control arm sold, 6 upper L 6 lower L 6 upper R 5 lower R control arms 4x4 available for sale
Pending sale 79-85 aisin locking hubs, axle shafts with birfield joints, exterior b pillar 84-88 single cab vent louvers, passenger 89-95 pickup door.
Pending sale 410:1 diff 8"
Erick561
1 Pair yota 4cyl tranny stiffener brackets sold, 2 pair left
79-83 4wd hilux passenger fender sold hawaii
84-95 alternator adjusting bracket sold, 2 left
81-90 EGR Valve sold, 3 left
85-95 41" 22re throttle cable sold
84-88 single cab exterior b pillar vent louvers sold
79-95 power steering pump bracket sold, 3 left
92-95 gray oval plug 22re distributor sold, 1 left
79-85 4wd rear solid axle tube sold
84-88 reverse sensor sold, 1 left
All caught up, i try to do same day shipping
89-95 4wd complete power steering box sold
84Flatbed
I've had a wanted ad on here for awhile but no luck. Im looking for a drivers side headlight door for a 84-86 4wd, pickup or 4runner. Not damaged and preferably black. Got one?
Erick561
Let me check, i know i sold my 85 black grill, i have 1-3 grills right now 84-88
Quote from: 84Flatbed on May 29, 2016, 09:18:20 AM
Erick561
85-95 complete 22RE cylinder head sold, 2 left, includes valves and cam
2 Pair of ifs locking hubs sold this weekend, 1 pair left
22R intake manifold sold, 1 left
92-95 gray oval plugged 92 Distributor sold
81-90 22R throttle accelerator butterfly sold, 2 left
84-95 3-line lspv load sending proportioning valve sold, 1 left
22RE Gas Tank Skid Plate Sold, gas tank skid plate bracket sold 1 left
82-85 passenger side 22REC Intake rubber tube elbow sold
84-88 hood latch core support sold, 1 left
22R transmission stiffener brackets sold, 1 pair left
3rd gen plastic dash board sold, 1 left
1st gen tailgate sold
Power steering pump bracket sold, 3 left
84Flatbed
Quote from: Erick561 on May 30, 2016, 08:25:58 PM
Thanks!
Erick561
84-88 22R Coil Igniter Sold, 1 left
84-91 4 cylinder manual mechanical speedometer cable sold, 1 left
22R 84-95 motor mount part pair sold, 9 left
85-95 Valve Cover Sold, 1 left
79-83 left front splash guard sold
86-95 manual steering gear box sold
4.10:1 third member & 89-95 chrome front grill sold, 410 gears available for sale, and about five hundred parts left
Erick561
Water pump pulley sold
22re throttle bracket sold 4 left
84-88 ash tray sold, 2 left
79-83 ash tray sold
88-95 22re intake tube sold
Sr5 gage Sold
2wd oil pan and oil pickup tube Sold, 1 pair left
84-88 gray kick panels Sold, 2 pair left
84Flatbed
Quote from: Erick561 on June 03, 2016, 10:55:17 AM
Chrome drivers side available
It's difficult for me to tell what you have there from that picture. Unfortunately, from what I can see none of them look like 84-86 4wd.
I learned the hard way that the 87+ headlight doors don't fit the 85-86 grill.
Erick561
I can't remember if the chrome grill is from an 84 or an 88 so i will take both of them apart and compare them.  I know the gray grill is from an 88
85 rear short bed single cab 4cylgas driveshaft sold, 2 left
Left and right 84-88 4wd fenders sold
84-85 windshield wiper motor sold (round plug) 1 left
89-02 ash tray sold, 1 left
84Flatbed
Quote from: Erick561 on June 04, 2016, 05:07:11 AM
Based on the emblem I would say 88. Also the 84-86 had 2 vertical bars in the grill, 87+ had 1 vertical in the center.
Erick561
Shipping 23 orders out from this weekend.  Please message me with parts requests.  Thanks
Erick561
Picked this up from my buddy yesterday
Quote from: 84Flatbed on June 04, 2016, 10:56:29 AM
